Advantages/disadvantages of shorter crank arms?
FactoryMatt
by FactoryMatt
o boy. can of worms here.... BUT....
shorter arms give you a narrower power band. it's harder to stay "on top" of a given gear. that said, they're theoretically easier to achieve maxium steady-state power with, all things being equal. depending on your muscle fiber composition and general phsyiology this may suit you or it may not. if you like to shift, it won't matter as much, but WILL be noticeable if you're sensitive and/or torque-limited. if you're running a wide ratio (cough SRAM 1x) cassette and a big chainring that exacerbates those gaps, you may find the shorter crank arms a bit uncomfortable on undulating terrain.
there are advantages to them like ground clearance & less shear force on the knees, and disadvantages like raising your CoG and profile & reducing your maximum available instantaneous torque (in addition to what's mentioned above in the first line).
morganb
by morganb
My max 1s, 5s, 15s, and 30s power haven't dropped at all going from 172.5mm to 155mm on all of my bikes (except 150mm on TT and gravel bikes). I also can get a higher top speed in sprints as I can get lower without my knees hitting my chest.
