tomee
by tomee on Mon Dec 30, 2019 5:17 am
anyone here fitted 160mm front disc rotors to a Giant Propel?
They are fitted with 140mm front and rear from factory and Giant made it have a propietry mount for the front fork.
wondering if i could just swap it out with a Shimano convertor?
jlok
by jlok on Mon Dec 30, 2019 9:39 am
Yes, you can. Done that before.
tomee
by tomee on Mon Dec 30, 2019 11:22 am
jlok wrote: ↑Mon Dec 30, 2019 9:39 am
would i remove the propietry giant mount and replace it with the Shimano mount, or can i pop the shimano adapter on top of it?
ruklaw
by ruklaw on Mon Dec 30, 2019 11:43 am
I'd try rotating the mount you have first (unscrew the mount, unscrew the caliper from the mount, rotate the mount 180 degrees and screw the caliper back onto it, screw it onto the frame).
If it's possible to use the shimano mount it's hard to imagine how the Giant one could work but not accomodate the same rotation that the shimano one does.
Just in case you aren't aware, with the standard shimano front flat mount, one way up is for 140mm rotors, the other way up is for 160mm.
jlok
by jlok on Mon Dec 30, 2019 6:06 pm
tomee wrote: ↑Mon Dec 30, 2019 11:22 am
You need to replace the Giant brake mount with the Shimano mount.
jlok
by jlok on Mon Dec 30, 2019 6:08 pm
ruklaw wrote: ↑Mon Dec 30, 2019 11:43 am
Maybe you could take a closer look before advising rotation of the mount... the Giant mount is actually flush with the fork. You won't want to do it unless you want a funny looking protrusion of the mount.
ruklaw
by ruklaw on Mon Dec 30, 2019 8:53 pm
jlok wrote: ↑Mon Dec 30, 2019 6:08 pm
Nothing that can't be fixed with a hacksaw then LOL
jlok
by jlok on Tue Dec 31, 2019 3:17 am
Pretty true, and it shaves grams!
Patb095
by Patb095 on Tue Dec 31, 2019 10:03 pm
ruklaw wrote:I'd try rotating the mount you have first (unscrew the mount, unscrew the caliper from the mount, rotate the mount 180 degrees and screw the caliper back onto it, screw it onto the frame).
Exactly, I went shopping bike at a giant dealer 1 mont ago and they said the exact same thing.
bas
by bas on Fri Jan 03, 2020 3:14 am
You need a Giant mount, the Shimano mounts do not work on the fork. I wanted to put a 160 on the front when I got my bike and was told I couldn't do it. But suddenly the 2020 models have 160 rotors...have ordered the 160 fork mount from Giant, you should be able to order from your bike shop.
jlok
by jlok on Fri Jan 03, 2020 4:16 am
- 160mm rotor on 2018 Propel Disc with Shimano mount.
tomee
by tomee on Fri Jan 03, 2020 4:42 am
bas wrote: ↑Fri Jan 03, 2020 3:14 am
no, you don't. i just did this today. Thanks to jlok for confirming
Also for those that are saying you can just flip the Giant propietry mount are wrong also.
stock giant mount for 140mm
mount removed. you can see you cant just flip it around for 160mm rotors.
Shimano mount installed
also converted the rears to 160mm
