Do you perhaps also have option to mount Go-Pro or light under that F1s computer mount?
Farsports F1 Integrated Handlebar/Stem
Yep, it’s already installed.
Wysłane z iPad za pomocą Tapatalk
Is anybody interested in selling the -3 degree sleeve?
I have just been fitted and my position still requires the change of cockpit angle. Unfortunately farsports probably has forgotten to enclose the sleeve to my shipment.
Why buy it? Email Farsports for that missing sleeve. It's their faultylukaszzsch wrote: ↑Fri May 10, 2024 9:54 pmIs anybody interested in selling the -3 degree sleeve?
Anyone with a Focus Izalco Max that' using the Farsports F1s are having any trouble with the spacers? Mine Are rubbing the frame and im not sure what to do anymore.
Hello,lukaszzsch wrote: ↑Fri May 10, 2024 9:54 pmIs anybody interested in selling the -3 degree sleeve?
the F1 comes with an additional sleeve, which changes the stem angle from 10° to 7°(....probably at least if beeing used with 1 1/8 steerer diameter...), is that correct?
Short info highly appreciated, thank you very much!
Its a 2° sleeve; so it changes the stem angle from -10 to either -12 or -8.reedplayer wrote: ↑Wed Jun 12, 2024 10:47 amHello,lukaszzsch wrote: ↑Fri May 10, 2024 9:54 pmIs anybody interested in selling the -3 degree sleeve?
Edit: appearently they changed it to a -3° sleeve now; the old one I have (bought the bars in 2021) is also a bit lighter (5g vs 16g) than the new one I saw in this thread
It’s -3 degrees sleeve but I was informed that is included upon request.
Nevertheless they sent me such sleeve for free.
Hello baumalein, Hello lukaszzsch,
thank you very much for answering, great info!
Best regards,
Best regards,
...and obviously it is no problem to run the F1 handlebar without, or just with very few, spacers.
Seems like a well-thought product, i only hope, deilvery-time does not take too long
source: https://www.bicycling.com/bikes-gear/a3 ... ou-faster/
To late, I ordered the F1 handlebar today, directly at "Farsport", but did not find any hint to the discount-coupon!
https://www.farsports.com/products/f1-h ... 4081917103
You can cancel the order and order it again with coupon They havent send you by now anywayreedplayer wrote: ↑Sun Jun 16, 2024 9:48 pmTo late, I ordered the F1 handlebar today, directly at "Farsport", but did not find any hint to the discount-coupon!
I am planning to upgrade my gravel bike (handlebar) with 105Di2 and F1 handlebar for some time now. I was now thinking of upgrading the handlebar now, and Di2 later.
Does F1s fit mechanical gearing as well? and is it a hard setup? So 2 cable housing on each side?
Currently the handlebar is wider and is still space to cut the housings, so will try to mount it with housings already in the bike/frame.
Does anybody have any experiance?
