1st attempt at WW build
shotgun
by shotgun
Crankycolnago wrote:
Thu Dec 05, 2019 3:26 pm
What are people using for light direct mount rotors ? Can't seem to find much out there .
I used Ashima adapters and Ashima Ai2 140mm rotors
prebsy wrote:
Thu Dec 05, 2019 6:00 pm
where did you get a kalloy stem for OD2/ 1.25 steerer?
From a buddy from Hong Kong. Alternatively, the Shimano Pro (non aero) stem is fairly light as well.
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
Nautiboy
by Nautiboy
Carbon-Ti X-Rotor 140mm @ 66grams each. Only issue is that it comes with 6-bolts configuration only, so if your wheelset is Centerlock, adding the adaptors would probably negate the money paid for such light rotors.
darnellrm
by darnellrm
It's a shame when 15lbs is considered a Weight Weenie build. fwiw
If you're not under 12lbs, your not even trying.
