Short nose saddles vs. classic saddles
JayDee81
by JayDee81
I am torn. Spent another 1.5 h on the S Power and there was no sign of numbing at all, which is great. I also got used to the rising rear of the saddle, so no longer a problem I guess, but after some 40 or 50 minutes my sitting bones started aching quite a bit. I was doing a low cadence workout, so I didn't want to stand up, so I shifter quite a lot forward on the saddle, so that the contact between my sitting bones and the saddle was completely different and after a short time it was ok to sit in the original position again for some 15 minutes.
I don't think this is a deal breaker, especially as this was on trainer. What do you think? Should I quit my search for a better saddle and stick with the S Power? At least for some time. It definitely solves my biggest gripe - numb perineum. Even though the thing is almost as heavy as a brick.
guyc
by guyc
I think a trainer exaggerates saddle 'issues'. I can't imagine (outside of a TT and I don't do those) when I'd be sat for 30-45 mins on the road. If it's solving what you wanted it to solve I'd stick with it for the road.
g32ecs
by g32ecs
guyc wrote:
Wed Jan 29, 2020 11:44 pm
It does. Honestly, I rarely feel numbeness outdoors unless I sit at the edge for long periods of time
It's terrible on the trainer because theres longer periods youre in the saddle just hammering away seated
Anyway, I have an experiment coming up. See photo attached. Some AliExpress specials have come my way
JayDee81
by JayDee81
So I managed to borrow Romin Evo and buy a cheap second hand Pro Stealth, so I'll try these two saddles. If neither is better than S Power, I will buy Power.
07stuntin6r
by 07stuntin6r
I have an sworks power on my Allez sprint and I’ve always felt like I’ve needed to scoot back during rides to get back on the seat. Contemplating if I need a longer nose saddle or if I need a better fit. Can’t really tell if I need the cut out or not cause I don’t feel much of that area being pressed in the gap if the seat. Any suggestions?
icantaffordcycling
by icantaffordcycling
Moving your saddle forward will probably put your sitbones in the correct position. You are naturally sitting where you need to be but the comfy/intended part of the saddle where your sitbones/rami are further back so you are scooting back. Try moving the saddle forward a couple mm.
JayDee81
by JayDee81
07stuntin6r wrote:
Thu Jan 30, 2020 10:14 pm
Longer saddle won't help you generally. You can try moving the saddle backwards as was suggested, but I rather think you should try playing with the saddle tilt a little bit, especially as you don't have any perineum problems. Try lifting the tip of the saddle 1 degree up and see.
TobinHatesYou
by TobinHatesYou
Yep, it’s astonishing how much 1deg increments changes the feel of a saddle.
07stuntin6r
by 07stuntin6r
Thanks I’ll try that. Just didn’t want to changed things from my last “fit” and mess with my knee angles etc.
wheelbuilder
by wheelbuilder
The whole thing with "cut-outs" and especially the really big cut-outs like the SLR Superflow which I use, is they are mostly intended for riders with great hip rotation and large bar drop. They work great and are super comfortable if you can maintain and ride in a flat-backed position. They are pretty terrible for more upright riders as you end up sitting right on the cut-out edges, and they are hard and cause quite a bit of chafing. The problem is a lot of recreational non aggressive position type riders buy the hell out of these types of saddles assuming they naturally must provide some relief when in fact they create a lot more discomfort than a non cut-out saddle would.
guyc
by guyc
Hour and a half turbo session today and deliberately stayed say the whole time to really test the Dimension. Zero discomfort or numbness. Happy with that.
07stuntin6r
by 07stuntin6r
wheelbuilder wrote:
Fri Jan 31, 2020 4:06 am
Don't get me wrong I haven't gotten any chafing or anything with the saddle. I must just need to move it forward like some suggested.
RedbullFiXX
by RedbullFiXX
Have not found this "chafing" wih any cut out seats I've used
Climbing or on the drops, always comfy
Cyclocross, in general, is about riding the wrong bike for the conditions.
TobinHatesYou
by TobinHatesYou
RedbullFiXX wrote:
Fri Jan 31, 2020 4:32 pm
People typically get chafing from too wide of a flare or too wide of a nose, not the cutout.
JayDee81
by JayDee81
TobinHatesYou wrote:
Fri Jan 31, 2020 7:22 pm
What do you mean by flare?
