campagnolo jockey wheel bushing to grease or not to grease
JoO
by JoO
Title says it all: should I grease the busing in the jockey wheels or not. Does not seem greased from the factory.
Miller
by Miller
One job I hate is cleaning oily crap off rear derailleurs. If I'm being diligent I take the lower cage off and clean everything individually. When I reassemble, yes I do grease or oil the bushings. Why wouldn't you?
kervelo
by kervelo
+1
I wonder why Campagnolo is not using real bearings in their jockey wheels.
JoO
by JoO
Pulley wheels with bearings like tacx don’t shift as good
bikeboy1tr
by bikeboy1tr
I always lube the RD pulleys no matter what RD I am running. I was using a silicone spray lubricant but it didnt last long as the pulleys would start to squeak. Switched over to Loctite Syn Super lube and it seems to get me through the week without the squeaking. As long as you dont spray a huge amount the mess is minimal and I give them a cleaning every so often when it does get gunky.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
LewisK
by LewisK
+1
I still have some of the Ceramic Speed pulley wheel oil left, so I use that which seems to do the trick!
wilwil
by wilwil
I use Purple Extreme lube. Definitely not grease.
