I've put on weight and don't know why
okimy
by okimy
I've been cycling for 2 years now and my weight has always been relatively steady around 64 kg. But lately it's gone up to around 66.5 kg and I don't understand why. I haven't changed my diet and trained as much as in summer, although now I'm on the turbo. It could be that I'm building up muscle (but why only after 2 years?), that my scale is off more than usual (it generally varies around 2 kg; last summer my weight was between 62 and 65 kg, now it's between 65 and 68) or that I've simply put on fat. Since I'm only 17 I reckon building up muscle is somewhat likely but I'm still interested in what you think.
TobinHatesYou
by TobinHatesYou
Don't worry about 2.5kg.
bm0p700f
by bm0p700f
Ha I gained that last Christmas and still got it. It was not muscle either
AJS914
by AJS914
If you are only 17 then you are still growing.
BitGid
by BitGid
Have you compared chest, weight, and hip measurements? Are your clothes feeling tight?
If the weight gain isn’t due to muscle mass and you want to reduce weight - and you mention eating more due to all the biking - you will need to change your meal plan.
But that doesn’t seem like the answer you want to hear.
d36
by d36
If you want the full story you really need to get a dexa scan
I've done cheapo tests/scans/bmi calcs and they were way off
Couple things I picked up (used to be high 70s pre cycling now low 60ish)
Water weight is a real thing
Fitter you get the more muscle you gain (but also fat loss)
Riding in summer = major water loss means my weight can yoyo 1-2kg (40 degree celcious days)
High carb diet = more water retention
High level of fitness = more carb/energy storage
High volume = Rediculous appetite means its easy to overeat (i.e gotta be disciplined on recovery days/weeks)
Low body fat (say 6-7%) = Makes it possible to put on a kg or two literally overnight (survival mechanism imo)
okimy
by okimy
Thanks for the answers. My chest and hip measurements have stayed the same but I've decided that i'll try to adjust my diet anyway. I haven't really got a plan but for now I'm cutting out some sweets and will see what works as I go along. Getting a scan probably isn't worth it and I'll continue to work on my power and endurance.
MattMay
by MattMay
Wouldn’t happen to be getting taller would you? At 17 you’re still growing...up.
okimy
by okimy
MattMay wrote:
Thu Oct 31, 2019 3:32 pm
Yeah I've checked that. Still 178cm, same as 1,5 years ago.
joeyb1000
by joeyb1000
If you just switched to the Turbo and you are sweating a lot, you may be just retaining water.
flying
by flying
10 seconds naked in front of a mirror will quickly tell you if you gained 2.5kg in muscle or fat :wink: 5.5lbs is a bit
LewisK
by LewisK
Check out this weeks cycling weekly, there is a good topic on indoor vs outdoor training. It did mention that when training indoors different muscles are used and you tend to use your quads more - this could lead to putting on a bit of muscle? Mind you, doubt you'd have put on over 2kg of muscle.
okimy
by okimy
LewisK wrote:
Sun Nov 03, 2019 7:17 am
I'll check it out, thanks for the recommendation. Putting on 2kg of quads seems a bit nuts, but I'm not just cycling. I do a lot of corework and tried out a climbing gym yesterday.
okimy
by okimy
Well, thanks for the answers everyone. After a week of training, a day of rest and an FTP test I'm back to my previous weight. I'm still wondering what kind of weight I put on (and lost now) but now I can at least stop worrying about losing it.
Leviathan
by Leviathan
for me, that weight is a hefty shit after a curry night. Honestly, 2.5 kgs one one sample isnt a real "gain" or loss.
