Durable tubeless tyre
MaxPower
by MaxPower
Hey
Just curious and might want to try tubeless.
The internet is full of reviews... But usually they are all about the "high performance" stuff.
I would like to hear people's opinion (no mud-fight thanks) on a "durable" tubeless tyre. What i mean with durable is a higher puncture protection than the usual "don't worry, the sealent will take care of everything so let's make the lightes tyre possible"...
For reference, the only thing i found that will keep punctures to a minimum are Schwalbe durano plus smartguard tyres (puncture like every second year).
I live in a area with flint (all over the place) so small punctures, but also bigger cuts, are normal here.
Miller
by Miller
Road tubeless is not as clearly delineated into 'performance' /'bombproof' categories as road clincher is. Nor are there many really light tubeless tyres: corsa speed, one or two others, that's it, and no-one should be using corsa speed as an everyday tyre. General use tubeless in 25/28 width is usually around 300g, give or take, and I have found such tyres to be robust even though some of them are very, very performant. I live on the edge of the Chilterns in the UK where the predominant geology is chalk with embedded flints. Historically I've had sh*tloads of punctures from little shards of flint. Since I switched to tubeless that category of flat has been effectively eliminated. Not saying there haven't been a couple of disasters, there have been, but that feeling of a tyre going squishy then rolling on the rim, it's not a familiar one in the way it used to be. Even a tubeless fail often leaves you with 20psi or whatever, enough to roll home carefully.
Let's see what others say.
MaxPower
by MaxPower
Interessting. Sounds a lot like conditions here.
But yes... That's what i am interested in. The performance/bombproof categories
naylor343
by naylor343
I've had good experience using Hutchinson sectors. Use it on the road, but also performs well on gravel too. Some reviewers complain of lack of wet weather grip, but I have not found this at all. It is possible that their grip issues are due to over inflation. I live in the pyrenees and I am happy on twisting descents, even in the rain, I have not lost grip.
alanyu
by alanyu
Giant AC0, IRC X-guard
willmac
by willmac
Pirelli cinturato velo is what you are after. Tread is 3.6mm instead of the usual 2.7 for gp5000, corsa, pro one. Rolls fast enough for winter. I've been looking for something like this for a while. Thick tread plus sealant should mean winter flats are a thing of the past
alanyu
by alanyu
willmac wrote:
Mon Oct 14, 2019 12:23 pm
My cinturato on rear wheel only survived around 1400 km. Yes, although cinturato got no punctures, it wore out quickly, ending up with one big bubble on the tread and one small on the side. If there was no bubbling, it could survive maybe 3000~4000km considering only the wearing, but that's still less than 4800km of pro one I rode with on the rear wheel from the late spring to the early autumn, which survived 4800km, with one or two punctures, but the sealent worked.
Sockman
by Sockman
Im running Vittoria Rubino G2.0 tubeless. Not so many miles to report on, but they were as easy to set up on my HED Ardennes rims as a regular clincher, and haven't flatted in about 500km of riding in mostly absolute slop conditions in and around Copenhagen.
The last ride I did with tubes was on corsa g2.0 28c and got 5 flats in 90km.
Marin
by Marin
MaxPower wrote:
Mon Oct 14, 2019 10:41 am
Hey
I would still try a regular tubeless tire like the GP5000, with a good sealant like Orange Seal. Chances are you won't notice any punctures at all.
MaxPower
by MaxPower
Nice to hear some first hand accounts on durable stuff.
It's not that i don't like high performance stuff, but for me the question of more durable TL is peace of mind and less sealant to remove from lycra and the bike 😁
kode54
by kode54
naylor343 wrote:
Mon Oct 14, 2019 11:41 am
I have also had good experience with the Hutchinson Sectors. Easy to mount and get sealed. no issues with grip in rain, i run mine at 50 psi.
One puncture I had with the Sectors...ran over some debris from a car accident remains...sliced the tire. i'm sure any tire wouldn't have survived that. Made a diagonal cut that was too wide.
- Factor 02 VAM Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Factor LS Disc + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs --> outgoing
MaxPower
by MaxPower
kode54 wrote:
Mon Oct 14, 2019 4:12 pm
How did you get home?
gnuehcwc
by gnuehcwc
alanyu wrote:
Mon Oct 14, 2019 12:22 pm
IRC X-guard +1
bm0p700f
by bm0p700f
I certainly noticed punctures with the contis.
Irc formula x guard is very durable and gives a pretty good ride. Punctures are far from frequent but being the puncture king I still get them. 6000km ft
Rom a rear tyre with an 88kg rider (kitted) and a heavy loaded bike.
Hutchinson fusion 5 all season last half as long but otherwise are fairly trouble free.
IRC roadlite not as durable or puncture resistant as the formula pro tyres but they are comfortable. Wet grip is not as good but still comparable to many other tyres.
Goodyear eagle. This would be a puncture resistant tyre. It transmits too much road buzz though.
I have yet to try the Victoria's but my expectation is the Rubin will last as along as Hutchinson all.season tyre.
The sector lasts well but lack wet grip.
I care little for how easy a tyre is too mount. IRC tyre levers make easy work of tight fitting tyres.
MaxPower
by MaxPower
bm0p700f wrote:
Tue Oct 15, 2019 7:50 am
thank you very much for sharing
