Lighter PM option than Rotor Inpower?
Nixster
by Nixster
I have a 170mm Rotor Inpower 3D30 single sided PM crankset with Praxis compact rings. Super reliable, never let me down and works with my etap FD. My only problem is the 720g weight of the setup exc BB which is PF30.
Suggestions for cutting significant weight at reasonable cost would be welcome! It pains me that I could get a Red crank for £250 and save 200g but then I would lose the PM. I am a Speedplay user so pedal based PM not currently an option.
Thanks in anticipation of your weight weenie wisdom!
wheelsONfire
by wheelsONfire
Perhaps the complete crankset (DUB)
https://www.quarq.com/product/quarq-dze ... gJgCvD_BwE
I guess the BB bearings could be the issue though!?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
VTR1000SP2
by VTR1000SP2
For dual, S-Works Power Crank - 615gr
Otherwise, just add 4iiii to SiSL2
Have you considered switching to lighter rings?
Nixster
by Nixster
Praxis rings are fairly light actually. Extralite would save a bit of weight it’s true but they don’t have the best rep with Etap.
I’ve thought about Sworks and SISL2 but both come out about £1k so fail the reasonable cost test. Sworks would save about 100g, SISL2 would be nearer to 200g so better value but still spendy!
philipeleven
by philipeleven
emmmm...
VTR1000SP2
by VTR1000SP2
philipeleven wrote:emmmm...
Uses 9100 chainrings?
philipeleven
by philipeleven
VTR1000SP2 wrote:
Sat Sep 28, 2019 10:45 pm
...or carbon-ti.... :D
ChiZ01
by ChiZ01
philipeleven wrote:
Sat Sep 28, 2019 10:51 pm
is there a regular 110 bcd version of the PM?
I like to run 46/34 and regular chainrings are dirt cheap
cnynrpr
by cnynrpr
I'm gonna add another option, not as light as the Specialized power cranks. The next lightest non-chinese option is the Easton EC90 SL crank (352g in 170mm viewtopic.php?t=158291) w/ Power2max NG/NGeco (154g) w/ praxis chainrings. You're looking at 506g for the EC90 SL crank w/ NGeco (https://power2max.cc/collections/ngeco- ... ith-cranks) and another 151g for the praxis for total of 657g.
VTR1000SP2
by VTR1000SP2
9100 rings are very light
NiFTY
by NiFTY
For single side i have a sram red bb30 w stages carbon nds. W bolts spacers and 150g q rings 172.5 arms and 130bcd it is 559g. In a compact w extralite rings it could be under 500g
Pinguin
by Pinguin
philipeleven wrote:
Sat Sep 28, 2019 10:15 pm
emmmm...
Graphics are too much
Is this a power2max spider?
velolive
by velolive
Pinguin wrote:
Sun Sep 29, 2019 4:49 am
emmmm...
It's chinese Sigeyi AXO spider. Cheap Power2max NG alternative.
Nixster
by Nixster
NiFTY wrote:
Sun Sep 29, 2019 1:41 am
This could be the winner thanks NiFTY. My Praxis rings are 134g so with those and 110bcd 170mm cranks could be looking at 525g ish? Solid saving of 190-200g for around £700.
Stages reliability is a bit of a worry, no?
Nixster
by Nixster
emmmm...
This looks promising if it’s US$600, probably £600 by the time it gets to me.
Unknown PM is a concern to me though.
With Praxis rings and bolts looking at 560g thereabouts so 160g saving, pretty impressive for double sided power.
