Power meter for Trek Checkpoint
LanceLegstrong
by LanceLegstrong
I have a Checkpoint ALR4 that I'd like to get a power meter for, but it has the worst crank clearance on the left side, so I'm not sure I can fit a power meter there. I know that Power2max has some options but I'd have to get new cranks. And Pioneer has some right sided only options. Any others?
jlok
by jlok
jfranci3
by jfranci3
Just space out a Stages/4iiiiiiiiiiiiiii with shims. https://amzn.to/2mWzcWt
I think the 4iiiiiiiiiiii rechargeable is the thinnest of the Shimano crankarm units.
Curious George
by Curious George
I have a Checkpoint and am running a Stages R due to the lack of clearance.
LanceLegstrong
by LanceLegstrong
jlok wrote:
Wed Sep 25, 2019 1:23 am
SRM MTB Pedals PM?
https://www.dcrainmaker.com/2019/09/srm ... r-srm.html
Looks nice, but way out of my budget.
LanceLegstrong
by LanceLegstrong
Curious George wrote:
Wed Sep 25, 2019 5:57 am
How do you like the Stages? I've heard mixed reviews of them in recent years. Though them and Power2Max seem to be the only options.
GPLama had this video about them, and specifiaclly the right sided Shimano crank-based ones: https://www.youtube.com/watch?v=M0tWTUwpt1k.
Last edited by LanceLegstrong on Thu Sep 26, 2019 3:38 pm, edited 1 time in total.
LanceLegstrong
by LanceLegstrong
So it looks like 4iiii also makes a right side power meter like Stages. Price for 4iiii is $600 to retrofit my 105 cranks. Price for Stages is $650 with Ultegra cranks. Is the Stages the better deal?
kafreeman
by kafreeman
Wait for black Friday and see what p2max offers.
I picked up a rotor 3d24 crank meter and rings for about 650 last year.
Sent from my SM-G965U using Tapatalk
jfranci3
by jfranci3
This Garmin sensor is 8mm thick. A 4iiiiiiiiiiii rechargeable is 7mm thick. With 2mm of shims, you should be fine.
https://forums.garmin.com/sports-fitnes ... -won-t-fit
If you can't space it, maybe run an MTB arm on one side and a 10mm pedal spacer on the other.
The Rotor 3d24s are gone. I think you need to go FSA or SRAM to avoid paying a bit more for the newer Rotor version. Another option is a used Quarq or P2M with a SRAM / Quarq GXP crank. There are old quarqs everywhere that work fine. The best PM deals are usually on Facebook - search photos and then limit the search to the current month.
LanceLegstrong
by LanceLegstrong
jfranci3 wrote:
Thu Sep 26, 2019 4:15 am
And that won't mess with the crank fitting?
jfranci3
by jfranci3
Welp... The pratical limiter would the crankarm lateral bolt (fixing), you're OK. I think the latest ones are 16mm deep or so. Trek on their carbon bikes already spaces the arm out +2mm on each side vs your BB86 fitting. You'd create a bit more lateral axis load on your non-drive BB bearing, but this isn't going to radically alter anything. +2mm is what you'd see going from a normal bearing seal on the BB bearing to a thick one like Wheelsmfg or BBInfinite sell. Shimano sells 6.5, 3, 2.5, and 2mm spacers for hollowtech II. Also, I think a common wave spring is 3mm. So spindle width wise, you should be fine, shimano infers it's OK, and you're not going to put a lot of off-axis load on your non-drive bearing moving it out a few MM.
2mm would be nothing.
LanceLegstrong
by LanceLegstrong
jfranci3 wrote:
Thu Sep 26, 2019 5:20 pm
Good to know, thanks.
jfranci3
by jfranci3
Also, I don't know if you've seen the MTB pedal hack if 2-bolt pedals are your thing - https://forum.trainerroad.com/t/a-wild- ... s/18627/24
LanceLegstrong
by LanceLegstrong
jfranci3 wrote:
Fri Sep 27, 2019 10:25 pm
That's pretty awesome. And now want to try it. With the UNO it'd be a lot less $ than the Rotor/P2M option.
jfranci3
by jfranci3
Well, plus you’d have a road / non-road / travel option as the mood changes.
