Hunt limitless VS Roval CL 50
otnemem
by otnemem
FWIW, Hunt's testing had those wheels besting or matching the world's best with 28mm tires.
jacobeh
by jacobeh
Campervan wrote:
Tue Sep 24, 2019 11:29 am
Wookski wrote:
Mon Sep 23, 2019 1:41 pm
Have Hunt’s rim designs changed since Hambini’s aero test where their 50mm design only tested 3W better than a mavic kysrium?
No Rovals on that report either. If Hunt 50's are so bad, why they they been on the podium on the tour de Britain last year?
You seriously think that wheels are making you win bike races?
Campervan
by Campervan
jacobeh wrote:
Tue Sep 24, 2019 12:01 pm
No, it's the rider, but I often see people quoting the report saying the hunts are rubbish. TBH, they is very little in the difference between most of the wheels at 30kph which is about 5%
BMC Granfondo 02 105
Scott Scale 940
Boardman CXR 9.4 cxr CX/gravel mongrel
Btwin 540
Specialized Venge Pro Disc
hambini
by hambini
If anyone believes wind tunnel tests conducted in steady state are valid. You need to go outside and shoot yourself.
Wind is neither parallel nor is it at constant speed in the real world.
This has been pointed out and none of the wheel manufacturers that have bothered to give an answer - that should speak for itself.
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
AJS914
by AJS914
Campervan wrote:
Tue Sep 24, 2019 12:03 pm
When people are paying thousands of dollars for wheels they want to know they are getting that last 5%, Otherwise, you could buy a nice set of $300 wheels.
pmprego
by pmprego
hambini wrote:
Tue Sep 24, 2019 2:18 pm
Thus my question in the first place. Should I then go for the lighter one? How much difference in drag am I getting if I ride in the middle of the pack? Assuming this "riding style" wouldn't the wheel weight be more important (as in the climbs I'll still have to push through regardless of air resistance)?
pmprego
by pmprego
AJS914
by AJS914
The 65 gram difference you are talking about between two wheelsets is almost meaningless. Plug a 65 gram difference into any calculator and you are talking about saving one second on a hill.
You are way better off optimzing rolling resistance, aero, tire/rim aero, etc. And don't worry about drag when you are sitting in the pack. Aero wheels come into play when you are taking pulls, attacking off the front, negotiating a crosswind, or sprinting.
pmprego
by pmprego
AJS914 wrote:
Thu Sep 26, 2019 4:37 pm
Thanks!!
MediumSizedMonster
by MediumSizedMonster
Dannnnn wrote:Having recently got the Rovals, They are brilliant.
I went for the them becasue A. they match my specialized bike and B they have DT hubs.
My only gripe is that the freehub is silent. Whereas the hunts will have a redicloulously loud freehub.
Upgrade the star ratchet on the rear hub to the 54t version. If you like noise, you will be very happy.
Dannnnn
by Dannnnn
I was planning on going up to the 36T first and see what it's like.
They've got a bit louder now they've good a few hundred miles on. Obviously they come with loads of grease in the ratchet
hlvd
by hlvd
Roval lifetime warranty changes things I guess?
Campervan
by Campervan
Dannnnn wrote:
Fri Sep 27, 2019 11:01 am
Is that on the 64's? Let me know if it's worth the upgrade?
The hunt's I also have are LOUD.
Scott Scale 940
Btwin 540
waltthizzney
by waltthizzney
AJS914 wrote:
Tue Sep 24, 2019 2:54 pm
There is NO way the different between carbon wheels will make you 5% faster. The difference between a shitty set of alloy wheels and carbon is probably closer to 1%
pmprego
by pmprego
waltthizzney wrote:
Fri Sep 27, 2019 9:18 pm
Unless you assume many youtube videos from people like GCN or CyclingWeekly are just lying to your face, there are videos out there showing how difference in wheels can have a 2kmh improvement for the same rider and power. That's way more than 1 or 5% actually.
