CamW's Raw Izalco Max Disc
CamW
by CamW
Managed to score myself an Izalco Max in my size with a cracked seatstay so fixing it up and obviously making it a little special along the way to dip my toe in the disc roadie realm. Completely stripping all the paint from the frame and clearing it with some simple vinyl decals.
Build list will be something like follows:
Frame & Fork - Izalco Max Disc XS
Groupset - Shimano Dura Ace Di2 Disc + Stages PM
Bars - Fizik Snake R1 40cm
Stem - Kalloy + Ti Bolts
Pedals - Dura Ace
Wheels - Wheelworks Maker SLD
Saddle - SQ Lab Carbon
Seatpost - Undecided (Throw me suggestions for a happy compromise between light and value with setback)
Tires - Vittoria Corsa TL
Hopeful for 6.8 - 7kg
Klaster_1
by Klaster_1
That's one light disc frame, although in XS! What't the weight of bare fork/frame? Is FD mount removable? How heavy is RD hanger? You can run regular 12mm axle, right?
BmanX
by BmanX
Clearly you have the skills to do carbon work so can you maybe bond a cheap and light carbon post into the frame and maybe bond the saddle as well? could be a very light set up to an already light set up.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
mike
Resident Pro
by mike
was the frame not raw already? it looked unpainted.
CamW
by CamW
Scale weights were original paint without any thru axle parts, or RD hanger. FD Braze on is not removable unless I take the dremel to it. I don't have an RD hanger weight which reminds me a need to purchase one. I will be running regular threaded axles on it.
While bonded in parts are definitely tempting I'm too much a fiddler to commit to that.
Frame was definitely painted. Whole frame picture was part way through the stripping process.
Squashednuts
by Squashednuts
Nice...
I had an Izalco Max Disc finished around 6.7kg
There was scope for more weight loss
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
reedplayer
by reedplayer
looking forward to this one, very curious about the weight saving of the stripped frame, i have a rim brake version with same paintjob!
regards,
reedplayer
by reedplayer
any updates? regards,
CamW
by CamW
Hopefully I'll be putting the clear coat on the frame and assembling it this week all things going well. So sick of sanding :|
Fork came out to 309g clear coated (excluding all hardware).
Frame as below. Might lose another gram or two before clear but that will obviously add a few back. I'll also pop a touch of reinforcement around where I add some holes for DI2 cables.
LewisK
by LewisK
CamW wrote:
Sat Nov 30, 2019 6:15 am
Haha I’m doing mine as we speak, it’s tedious yet very rewarding. Impressive frame weight, well done 👍
reedplayer
by reedplayer
wow, 67 gramm for the frame is amazing weight loss, considering, that you started with a matte frameset.
izalco max seem to have very strong matte coatings. i remember ax lightness claiming a 10 gramm for the coating of vial evo.
so, stripping frame could reduce my rim-izalco-max`s weight (size s) to ca 650 gr. frame/257 gramm fork.
looking forward to the progress of your izalco, please keep us updated. Thank you!
dereksmalls
by dereksmalls
What length stem Cam? I've got a spare Extralite in 110mm
CamW
by CamW
Uhhhhh, probably 110mm!
CamW
by CamW
reedplayer wrote:
Sun Dec 01, 2019 7:33 pm
Some of that weight loss was the metal chainstay protector and a foam tube inside the frame for the rear brake cable so your results may vary.
reedplayer
by reedplayer
Hello,
thanks a lot for your specification
yes, this for shure adds few gram, but propaply not much.
mine is one size up, i could imagine this might compensate protector and foam.
