Are 650B really more comfortable than 700C?
fourfa
by fourfa
redbicycle wrote:
Sun Sep 15, 2019 1:24 am
spdntrxi wrote: Try ReneHerse/Compass or some WTB byways.. I run my WTB byways @ ~30psi they are 650x47... and it's a couch.
At what weight are you riding at this PSI? I'm 200lbs and honestly a bit scared to try such a low (in my mind) psi.
I'm 200, I run my road GP5000TL at 90 psi (very smooth roads around here), I run my 650b wheels (WTB Ventures) at 40psi on road (rated max for these rims) and 25psi off. Haven't bottomed out yet
redbicycle
by redbicycle
Thank you
LeDuke
by LeDuke
My wife’s new gravel bike will have her running <20 psi with Tubolight inserts and 650x50mm tires.
Comfort, traction and speed.
NS
by NS
I run Maxxis pace 2.1 on my 650b at 30psi schwalbe g one 38s at 40psi on 700c
emotive
by emotive
A 46mm x 700c tyre has 230 cubic inches of air volume.
A 52mm 650b tyre has 250 cubic inches of air. About 10% more air, so you could run air pressure 10% lower for the same amount of suspension.
However, being a bigger tyre you have more travel before risking a pinch flat, so you could drop MORE Than 10% and get a bigger increase in comfort and grip with the same tyre safety.
46mm is already a big tyre. For others considering the switch from 700x40 to 650x48, the numbers are 160ci vs 200ci, or a 25% volume increase.
