Ceramicspeed Driven - shifting teaser
Karvalo
by Karvalo
MichaelB wrote:
Mon Sep 02, 2019 11:40 am
aeroisnteverything wrote:
Mon Sep 02, 2019 10:36 am
For all the skepticism: this is obviously pretty similar to how a car's driveshaft works....
I think you need to look inside a car differential and see just how different that is to the CeramicSpeed marketing crap.
No kidding. Bikes don't need a differential :noidea:
gurk700
by gurk700
all that shit to save what? 3-5 watts? lol
themidge
by themidge
^ +1! When they say their drivetrain is 49% faster than a normal one or whatever, the first thing we should all be asking is how much drag does a normal drivetrain create in the first place?
What's that? Hardly any you say? Well then, I won't bother.
TobinHatesYou
by TobinHatesYou
themidge wrote:
Mon Sep 02, 2019 8:27 pm
It's 98% to 99%. So for a pro in a 1400W sprint that would be...14W. And that's assuming those crazy perpendicular loads I mentioned don't create a whole lot of friction...and that the rear triangle is rigid enough to handle that kind of force.
And then we need to consider the comfort penalty with such a rigid rear triangle contributing too...
MichaelB
by MichaelB
Karvalo wrote:
Mon Sep 02, 2019 6:20 pm
Really ? :roll:
What I assumed aeroisnteverthing was referring to, and expected others to do the same, was the change in drive direction, not whether a bike needs a differentional. :noidea: to you too.
themidge
by themidge
TobinHatesYou wrote:
Tue Sep 03, 2019 2:26 am
...crazy perpendicular loads...
I think you've hit on the biggest flaw with this system with that idea. It makes the most sense to me anyway.
I wonder whether this 'groupset' will only be used* in triathlon/ironman events (for marketing purposes probably) where riders won't be getting out of the saddle much.
*if it is ever used
Alexbn921
by Alexbn921
themidge wrote:
Tue Sep 03, 2019 12:10 pm
*if it is ever used
It will never be used as it is physically impossible for it to have a high efficiency then a chain. Not only that, but it will never be anywhere close to even double the weight of a conventional drivetrain.
Let’s take for example that you need at least 4 bearings on the driveshaft. Once loaded they will each take about 1-3 watts. That’s 4-12 watts of bearing drag in just the shaft. Add in the contact bearings and you have another 1-2 watts times 2. We are already at 6-16 watts.
Now you also have to factor in the huge increase in side loads experienced by the hub and crank bearings. You will have to use angular contact or needle bearings adding another 4-10+ watts.
Grand total of a perfect system will be at least 10 watts and more likely 20+ watts. At a 300 watt FTP with 20 watts of drag you have 93% efficiency.
Also add in at least 1kg for reinforcement to the frame and drivetrain.
https://www.neugart.com/en-us/planetary ... e-gearbox/
wheelsONfire
by wheelsONfire
I would buy in to it, if it's extremely expensive and really bling!
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
spdntrxi
by spdntrxi
wheelsONfire wrote:
Tue Sep 03, 2019 8:27 pm
it's ceramicspeed.. you can count on that.
wheelsONfire
by wheelsONfire
spdntrxi wrote:
Tue Sep 03, 2019 8:45 pm
Puh, then i feel ok to take another loan. The more the better.
Anxiety over debts are well worth it if i am unique :D
To be fair, it would be extremely interesting to have the bike for a few days and ride solo.
Bikes:
Ex bike; Vial EVO D
TobinHatesYou
by TobinHatesYou
Also what about high-G impacts like potholes, bunny hops. Chains just flap around.
What about wear and tolerances? Derailleurs deal with any slack in a chain and can be indexed. How can this system possibly adjust its equivalent of a b-gap without severely compromising its strength?
ichobi
by ichobi
There's a feature article on cyclingtips for a close look.
IvanZg
by IvanZg
From cyclingtip's article:
"Currently, CeramicSpeed’s newly rideable prototype is only meant to withstand about 200W."
gurk700
by gurk700
IvanZg wrote:
Wed Sep 04, 2019 11:18 am
:lol: that sure saves watts!
ichobi
by ichobi
Unless they use vibranium I can't see how they can make it light and strong, and viable.
If anything this could just be a marketing show, just like most of the thing CeramicSpeed does.
