2020 Schwalbe Pro One
refthimos
by refthimos
I really wish there were some 3rd party rolling resistance data for these. It seems like BRR and others take a long time from when a tire is available to when data is presented. I get it, the data are free so maybe we get what we pay for, but I would be happy for a Friction Facts type model where testing of new "contender" tires (GP5000, Pro one TLE, Corsa variants, etc) was done right at release for a fee of $2.99 or something like that per report. Sure the data would get out, but I would be happy to fund testing if it meant we could get timely data.
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
Shiv Tri Disc | AXS | SISL2 P2Max | Enve 7.8 | Ascalons/Titan/Aeox Utimate Disc coming
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
Dan Gerous
by Dan Gerous
Imaking20 wrote:
Fri Sep 13, 2019 3:48 pm
Yes.
I thought the first Pro Ones sucked (in terms of ride quality and grip). Which makes me even more surprised by the new ones. They definitely don't feel "supple" in the hand, but ride has been killer. Not far off the comfort of the 28mm cotton tires and latex I just took off - and handling is excellent.
That's good to know. Let's see how they hold up in the longer term now, by then I'll have worn out my current stock of tires. :mrgreen:
petromyzon
by petromyzon
Perhaps Jarno from BRR should have a donations page where people could pledge a small amount towards him buying the latest tyres.
However, I suspect it is probably a time limitation as well - doubt that website is his full time job.
by Nefarious86
Orlok wrote:
Nefarious86 wrote:
Thu Sep 12, 2019 7:38 am
TLR or latex?
Sent from my SM-G977B using Tapatalk
TLR AND Latex.!
You knew what I meant lol
Using Tapatalk
Imaking20
by Imaking20
First puncture on these today. Took a bit longer to seal than I would have expected (probably lost 3x as much sealant is it would typically take me to seal a tubular) but it eventually sealed and I went about my merry way for another 50 miles (even snagged a KOM from Travis McCabe!)
Using orange seal because it's what I had (and it's awesome). Also where I got these tires didn't have the recommend Schwalbe blue stuff.
aeroisnteverything
by aeroisnteverything
Imaking20 wrote:
Sat Sep 14, 2019 10:10 pm
Would be great to hear what caused the puncture?
Also, how does the tread look after riding? Do you see cuts to the tread from chipped stone?
Imaking20
by Imaking20
I'd also love to know what caused the puncture :)
With a couple hundred miles on them so far (including a fair bit of roadside debris and some jaunts on gravel) there are no cuts at all. In fact, there are still little bits of rubber from the moulds (at the seems, don't know what to call them) that haven't worn off.
I'm planning to rotate the tires after 1k miles. Coincidentally, that's what I was thinking about on Saturday right before getting sprayed with sealant.
TobinHatesYou
by TobinHatesYou
Doc Blue is just Stan’s...
Sjazzzzy
by Sjazzzzy
I swapped from the previous generation of pro ones to these new ones for a long ride over the weekend. It was a new route but within the first mile I could tell they are much more "supple" than the previous generation. They also mounted much easier than the old ones. I mounted the first tire with a booster pump but the second I used just a regular floor pump. I was able to seat the bead no problem. Only issue I ran in to is that near the end of the ride I lost a lot of air. When I stopped to find the puncture/leak, all I could find was a small pin hole on the sidewall with a little bit of sealant bubbling out. I suspect my stash of 5 year old stans needs to be replaced or I need to put more than an ounce of sealant in per tire. I pumped up the tire with my frame pump and it's been holding air since. I'd definitely recommend these.
robeambro
by robeambro
We need an enthusiastic user of GP5KTL/New Spesh TLR to try these out and draw a comparison. And of course, we also need BRR to give us figures. Possibly, all this before I will need to replace my rear tyre..
AnkitS
by AnkitS
robeambro wrote:
Tue Sep 17, 2019 6:46 am
No pro ones yet but I have ridden the spec rapid-airs for 400mi or so.
They ride like a mix between turbo cottons and the non rapid-air tubeless turbos.
I mounted the gp5000s but decided that the weight and difficulty to take them on and off wasn't even worth riding them.
My experience with the outgoing pro one tubeless was short-lived with a sidewall gash (glass or metal shard i think?). If I was paying full retail for rapid-airs, I would prefer fusion 5 performances.
Why I quit WW. Bike updates all on instagram
robeambro
by robeambro
icantaffordcycling wrote:
Tue Sep 17, 2019 8:28 am
Nooo you should have ridden the GP's! :lol:
I mean, the 50g (?) weight penalty shouldn't be a factor. In no way, shape or form would that be even remotely important when compared to rolling resistance benefits. When picking a tyre, IMO it should all be about RR + Grip + Puncture Resistance.
But I understand the difficulty about taking them on and off can be a turn off.
If the Rapid-Air's aren't such a formidable tyre (otherwise you wouldn't have mentioned that at full retail you'd rather go for the Hutchinsons), then the only hope for a king tyre is these new Pro One..
scapewalker
by scapewalker
Will they come in different color options like other Schwalbe tires have in the past?
If so i'd pick them over the GP5000s anyday :D
kevinw
by kevinw
Worth mentioning that the GP5Ks do stretch over time so removal and re-fitting "on the road" was not an issue for me even after a nightmare fitting them originally.
Both my GP5K tyres dies within 1000km though - one with a massive gash and the other the sidewall went. Currently running fusion performance until something comes along definitely better or enough GP5ks are sold that I can be sure mine were a bad batch.
These new pro ones look great though - not going to rush into anything this time though.
Alexbn921
by Alexbn921
LOL. I went from the old newest Pro Ones regular to the 5000GP TL, both in 28. I felt the pro ones had more feel at the limit but am getting used to the 5000GP TL with 900miles on them. over all they are a great tire. I too am interested in trying out the new offerings from Specialized and Schwalble. I don't think either one will roll better though.
I’m willing to give up some RR for grip.
Ride fast Take chances
