2020 Schwalbe Pro One
Orlok
by Orlok
Alexbn921 wrote:
Wed Oct 23, 2019 11:28 pm
New Tire Day! 28mm
Got some GP5000lt from a warrenty claim, but decided to go try out the Pro one TLE.
Pretty easy to get the front tire on. Rear was only slightly harder. Super easy to pop them onto the beads. On DT Swiss ERC 1000 Dicut wheels.
Meassure 27.6mm. we will see how they streach. rought road just seems to disapear under them. Big hits are harsher. I think the reduction in volume has an effect on the bigger hits. Pro ones feel faster at high speed but now as fast at slow speed. They are taller then the GP5000lt too.
What were the problems for your warranty claim.?
Once comes a time that you'll have a tailwind :D
Pinarello F10 - Ultegra 8050 Di2 - Carbonspeed C38 Tubeless
Alexbn921
by Alexbn921
The sidewalls where coming apart. Threads where breaking and hanging off the sides of the tires. Was not from damage of any type.
Ride fast Take chances
kevinw
by kevinw
Alexbn921 wrote:
Thu Oct 24, 2019 7:33 pm
I had the same, also warranty replaced and sold new ones on eBay.
refthimos
by refthimos
I recently had a 5000TL that had a weird bump/bulge in it. Tire was seated fine on the rim fine, but it had this large bump/bulge. Swapped another 500OTL on and everything was fine. Continental warrantied the defective tire, so overall NBD.
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 Disc | 9250 | P2Max NG SL | Ascalons | TroikaMax or Titan/Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
Leeroy996
by Leeroy996
What pressure are you guys typically running in the new Pro 1's ?
I've done about 1600 miles on the tires typically runnning at 85-95 in my 28mm. Mavic Cosmic UST wheels.
Coming off the Mavic Yikson tires I find these very harsh and difficult to get confident in corners. I would've kept running the yikson if they were a little more durable. I tried the GP5000 but couldn't get them on the rim.
The tires have developed a visible ridge where the two compounds meet. Durability has been good so far. I've had one puncture in the front that covered me in sealant, only lost about 12 psi.
Alexbn921
by Alexbn921
I run 70 front and 72 rear. 185lb rider weight
Imaking20
by Imaking20
I was doing 72-75 psi. 160 lb weight currently
Leeroy996
by Leeroy996
Is that pressure on 28's ?
I'll try the lower pressure tomorrow, I'll be doing some descending with a few nutters.
Interestingly Mavic have just come out with a "Yikson Pro UST 2".
Dan Gerous
by Dan Gerous
Leeroy996 wrote:
Sat Oct 26, 2019 1:28 am
That's a lot of pressure for 28mm tubeless, no wonder they feel harsh and lack grip, I would definitely go lower.
Imaking20
by Imaking20
Nah, I'm running that on 25s. The pressure you're running is kinda nuts. I wouldn't run that high on 25s - 28s must suck.
tonytourist
by tonytourist
Imaking20 wrote:
Sat Oct 26, 2019 2:05 am
161 bro :unbelievable: :unbelievable:
Leeroy996
by Leeroy996
Imaking20 wrote:
Sat Oct 26, 2019 3:25 am
Yes, doesn't feel great with these Pro 1 tires. The higher pressure was fine on the yiksons, edge grip and feel were incredible.
TobinHatesYou
by TobinHatesYou
Yksion Pro USTs have a max rating of 87psi for their 28mm tires, so that should say a lot about you running them at 85-95psi.
MattMay
by MattMay
kevinw wrote:
MattMay wrote:
Thu Oct 10, 2019 8:35 pm
I just mounted 25mm Schwalbe Pro One tubeless on 21mm internal width rims (Light Bicycle) and they measure 28.2 after a week at 75psi.
Are they the 2020 version? I thought they would be smaller.
So I bought a special one-off set made for the Tour Down Under, mostly because they are tanwall. I’m guessing that may explain some differences. Image
Dan Gerous
by Dan Gerous
MattMay wrote:
Sat Oct 26, 2019 4:13 pm
These are the old ones, not the 2020 redesign.
