Reversible offset seatposts?
wheelsONfire
by wheelsONfire
I'm looking for tips regarding reversible seatposts
Example, setback 10 - 15mm but with possibility to run offset forward.
My Bike Ahead for instance isn't possible to use in reversed position.
Bikes:
Open *UP* (2016.04.14)
none
by none
For what diameter?
I have some Corima seatposts.. only fits 27.2 or 25.0 mm
MayhemSWE
by MayhemSWE
Seatposts are typically not reversible because of limited range on the saddle angle adjustment. The only posts I know of which are officially endorsed by the manufacturer to be run in both orientations are the Profile Design Fast Forward Reversible and Redshift Dual-Position.
JoO
by JoO
Adam hansen flipped his Deda seatpost
https://bikerumor.com/2017/01/16/tdu-20 ... elium-slx/
Dan Gerous
by Dan Gerous
So did Gorka Izaguirre with his FSA K-Force:
In some cases, even though it's not supposed to be doable, swapping mounting bolts for different lengths can make it work.
wheelsONfire
by wheelsONfire
MayhemSWE wrote:
Tue Aug 13, 2019 4:36 pm
I've looked at the Fast Forward. But it seems it will actually move the saddle to much.
I look for a difference on 10 - 15mm. I tried to check if Beast components works, but they didn't reply.
I look for something under 150g.
27.2mm version.
Bikes:
roadman
by roadman
FSA SLK ITC has two offsets. Not light though
