Bike MEdia Rant - 2018 Madone SLR Disk 19.2 lbs, ouch!!
DucHunter
by DucHunter
It's an aero bike and I live in Florida so it’s not that big a deal. Still I am growing VERY tired of OEM's saying their bikes are "light weight" when they are not at all. Same goes for much of the "in the tank" bike media. I am sorry but there is nothing "light weight" about any road bike in a 60cm that weighs more than similarly sized hardtail MTB's. By contrast my Gen 1 Cannondale Evo Ultimate (super light bike I know) was under 14lbs as built, and not with all crazy light parts.
My Madone is a PJ1 build, all Ultegra Di2 R8000, Garmin Vector 3 pedals, Enve 4.5AR rims on King R45 Ceramic hubs, and Vittoria Corsa 2.0 28mm tires (tubeless), Bontrager RXL bottle cages, and a Bontrager Montrose Carbon saddle. It's an amazing bike, super-fast, and I love it.). Light weight, it is CLEARLY not. It’s not built with the lightest parts (going to Dura-Ace would shave about 200g), Enve 5.6’s though would only shave a few grams. It’s much heavier than the Cervelo S3 Disk that preceded it, and the S5 that preceded that. It’s even heavier than my 61CM Cannondale SuperX (Ultegra Di2), when that bike was wearing the same wheels and Schwalbe Pro One Tubeless. What gives?!
Bikes I have had and their weights
  • 2012 Trek Speed Concept PJ Spartacus (L), Di2, Bontrager Aeolus 9 tubies, Quarq/SRAM crank (17lbs)
    2017 Cervelo S3D (58), SRAM Etap, Quarq Power Meeter, Enve 5.6/King R45 Ceramic (18.2lbs)
    2017 Cannondale SuperX (61cm), Ultegra 8k Di2 Disk, Enve 4.5AR/King R45 Ceramic, Schwalbe Pro 1 28mm, Cannondale Si Quarq Crank, Carbon cages, 45mm Deda Drop Bars (Carbon) & Alu Stem, XTR MTB Pedals (18.6lbs)
    2014 Seven SLX Custom, Campy Super Record EPS Rim Brake, Zipp 303 Tubies w/R45 Ceramics, Fizik Kurve Saddle, Cannondale Si Quarq Zipp Carbon bars/stem, Zipp carbon cages (16.2lbs)
    2012 Cannondale Evo Ultimate (60cm), RAM Red 10 spd (remember that lovely groupo), Cannondale Si Crank with a Quarq power meter, Zipp 303 Firecrest Tubbies with Chris King R45 Ceramic hubs, King Ceramic BB, Look Keo pedals, Zipp Carbon bottle cages, and a Fizik Antares Carbon Saddle.
The new Madone is 2.2lbs heavier than a 7 year old Trek Speed Concept? Yeah one had tubies and one is a disk tubeless, but that’s not progress. LOL! The Madone is .8lb heavier than a 2 year old carbon gravel bike using the same wheels (SuperX)?? The Madone is 3lbs heavier than a carbon/Ti lugged custom built frame (yea the Seven has tubies, and older Super Record ESP).
It just amazes me that “everyone” in the bike media calls many of the new bikes, the Madone included, “light weight,” as do the OEM’s. Yes aero bikes are never going to be as light as bikes that are not pure aero bikes. The new Evo though seems to be about 10 watts slower in the wind than the SystemSix (on the same wheels) and my Madone, yet it builds up to more than 3lbs lighter with similar equipment. 1,361g lighter for a cost of 10 watts? Ouch.
Well that’s my rant. Love the bike, don’t mind the weight in Florida, but DAM! If I still lived in Nor Cal I would not be on an aero bike….I don’t think.
flying
by flying
Drink the Bike Media's "Aero is where its at & weight no longer matters" Kool-aide it is all the rage now :thumbup:
raisinberry777
by raisinberry777
DucHunter wrote:
Sun Aug 11, 2019 12:42 am
Sorry, but I have to call BS on this - at least for the cycling media. Here's the first five reviews that came up on Google.
BikeRadar
No mention regarding the weight at all, except for the wheels, described as 'light for their depth'.
Cycling Weekly
The Trek Madone SLR 9 Disc Weight-wise we’re looking at around 1,000g for a 56cm frameset according to Trek and my size small 52cm complete is 7.5kg on our scales, which is competitive for an aero bike and is in large part thanks to the use of the high-end and much respected OCLV 700 carbon, the American brand’s highest-grade carbon – although there are lighter aero bikes out there.
So not calling it lightweight - just competitive for an aero bike, and noting that there is lighter out there.
Gran Fondo
Because of the relatively high weight, the Madone lacks a certain liveliness off the mark, but still accelerates nimbly in bunch-sprints and out of corners. The Madone is an efficient climber too, provided you’re not chasing a KOM on really harsh gradients, though that’s undoubtedly due to the somewhat heavier system weight.
Fairly negative on the weight there.
Road.cc
But it doesn't feel quite as snappy at lower speeds, out of tight corners, and the weight holds it back on steeper gradients.
All the parts build up to a 7.7kg weight for the size 56cm bike tested. For comparison, the Specialized S-Works Venge in the same size and with similar parts tickled the scales to 7.15kg, so the Madone is carrying a bit of timber.
Again, pretty negative on the weight.
Cycling Tips
But is the Madone SLR fast? And is it light? I can only objectively confirm the latter, as my 52cm sample weighed 7.70kg (16.98lb) without pedals, but with cages — not far off from the claimed figures, but still within the ballpark given the thick coats of paint (and paint is surprisingly heavy).
Although reviewer James Huang clarified this in the comments.
Sorry, that may not have been the best choice of wording. What I should have said was that I can only confirm the weight, not that it was unusually light.
wheelsONfire
by wheelsONfire
The negatives with a higher weight is that the bike lose it's snappiness. On the other hand it might iron out vibrations and run more stabile.
I have a ti/carbon frameset - this is really heavy (aka not snappy at all)!
Not sure i would expect "light" weight from a larger size aero bike with custom paint work.
Do you have any pictures of the bike?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
DucHunter
by DucHunter
Well I guess I am too old school, or an outlier all together. My whole point was a carbon bike that is over 19lbs in a 60cm, one that weighs as much as a similarly high end hardtail MTB should be written up as heavy. A new aero road bike that is 2.2lbs heavier than the same companies 7 year old TT Super Bike, which are tyalically a lot heavier than their road counterparts, should be given a hard time too. It should maybe even be classified as a fast tank. Yet we hear nothing very negative about them at all (inspite of Mr Raisinberry777's comments above). Especailly considering that competative bikes are all lighter by a fair bit. I guess y'all think +19lbs for a high end road bike is totally cool, aero or not.
How many watts of aero woudl you give up to drop poundage? As I said above, -3lbs for +10 Watts?
Totally agree with the snappy-ness comment. The Madone is not unsnappy for me, but I can put out a lot of power to (+1,000 Watts) jump across a gap (holding that for a long time is a stiff story). My guess is we will either see these bikes get a lot lighter soon, or they will go the way of teh Dodo Bird in favor of bikes like the new EVO/Tarmac/F12/R5 that are within 10 watts aero-wise, but weight a lot less.
Noctiluxx
by Noctiluxx
Your Garmin pedals, Ultegra hydraulic groupset, Enve 4.5 AR's, 28mm tubeless tires with sealant, 60cm frame, are all moderately heavy. My 2019 Madone SLR (52cm) Rim Brake with DA 9150, XXX 6 wheels, Conti 5000 25mm (clinchers), Speedplay Zero Ti pedals, Tube bottle cages with Bontrager XXX saddle comes in at 16.0 lbs.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
anykarthik
by anykarthik
I ended up at 17.5lbs for a 54cm Venge Pro (Ultegra Di2) with Speedplay Cromo pedals, Syncros cages, Selle Smp Glider saddle, stock Garmin mount, all spacers installed and Hutchinson tubeless tires (25f, 28r)
Not a "lightweight" bike, but plenty light enough for me. Not sure the Tarmac Pro Disc similarly spec'd would be too much lighter - maybe 0.5 to 1 pound?
The Madone was always reviewed as a heavy bike (all those Isospeed bits) - I don't think anyone claimed it was light. That said, you can get similarly aero (Venge) at a much lighter weight (see above), but I suspect you Madone riders are significantly more comfortable.
Mep
by Mep
The media is always misrepresenting things, that part is not new. But definitely not all is lost: my Madone rim brake comes in at 13lbs with tubular wheels. Not bad but certainly heavier than my SS Evo.
mdeth1313
by mdeth1313
flying wrote:
Sun Aug 11, 2019 1:05 am
Yup, until you hit that first, long upgrade, it's all good.
Speedplay is the devil!
gwilson
by gwilson
Noctiluxx wrote:
Thu Aug 15, 2019 12:04 am
My bike is very similar to his and still noticeably lighter. I have a 60cm Madone SLR 6 disc (Ultegra mechanical) with Bontrager XXX 4 wheels. Everything completely stock with two bottle cages, garmin mount, and light mount I weighed it at 18.25 lbs. Previously had a SystemSix Dura-Ace which was almost the exact same weight but significantly more uncomfortable, so I thought the weight was actually pretty good for a 60cm comfortable disc aero bike with ultegra.
ryanw
by ryanw
Ok, it’s not a full aero bike, but I just built up a 61cm S-Works SL6 Disc with R8070 and CLX50s, that came out at 7.45kg with pedals and cages etc.
Nothing exotic on it at all. Heavy saddle, cockpit etc.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
Hexsense
by Hexsense
DucHunter wrote:
Wed Aug 14, 2019 9:59 pm
3lbs is likely less than 2% of total system weight for most people. (me for example, human+bike is around 170lbs. extra 3lbs is 1.7%).
at slow 20mph, generally people solo at around 180 watts (depend on body size and position). You need to save only 3.6 watts at this speed to save more than 2% of total drag.
And i'm not saying weight related drag = wind related drag either. Generally wind related drag >>>> weight related drag. According to http://bikecalculator.com/. Even on 6% grade, 180 watts with weight of 170lbs is still slower than 183.6 watts (180watts actual +3.6w free watts) at 173lbs. So you need something steeper for 2% of lower total weight to outpace 2% of total aero drag.
I'll even take 10lbs extra weight for 3watts drag reduction (at 20mph) after all these calculation.
pmprego
by pmprego
Hexsense wrote:
Thu Aug 15, 2019 10:11 pm
That is true if you ride solo all the time. That's why you still see the pros riding the lightweight versions. The seconds are usually gained on steep top finishes.
But as it was said. The venge is a bike that really blurs the line between aero and all rounder.
jasonh
by jasonh
I don’t think anyone that purchases any project one bike, especially a Madone would be surprised by the weight.
If the media were to call out the weight, as they should, they should justify it by elaborating on the isospeed features, the high level paintwork and finishing, along with aero tube profiles.
I think Garmin pedals along with those wheels, as opposed to Aeolus xxx wheels makes a difference.
That said, I’d like to see trek add some tire clearance for bigger rubber. It’ll NEVER happen bc it would take away from their checkpoint and Domane sales.
FactoryMatt
by FactoryMatt
its pretty lame how all the sudden 7.5kgs is an acceptable weight for a $10K roadbike. we're tracking the car industry here.
and GCN et al pretty much solely exist to push trends by spouting half-truths out of context. wider tires aren't always faster. 1x isn't always better. a 48/10 top gear is no where near as efficient as 50/11. disc brakes are not always better. it's not "only" a half kilo penalty. etc etc etc.
like there's nothing wrong with pushing aero disc bikes, just be real and call a heavy bike heavy.
it's like every car review on crappy electric power steering - "it's not quite as lively as the hyrdraulic racks of old, but its got pretty good feel for what it is!" nooo, it's dead. just say it's dead. don't move the damn goalposts.
