icantaffordcycling's 1x Allez Sprint
icantaffordcycling
by icantaffordcycling
Currently 7.71 kg with the CLX 64s.
Last edited by icantaffordcycling on Fri May 29, 2020 12:23 am, edited 10 times in total.
icantaffordcycling
Tentative build list
Allez Sprint Disc Frameset 49cm
Specialized headset
Praxis 6806 BB
ENVE Expander
9170 DA di2 shifters + callipers
Ultegra RX-805 rear derailleur
3 port junction A (mounted at bb)
DT-110A internal battery
XX1 11 speed chain
S-Works Power Crankset 165mm
J&L or SRAM 42T narrow wide chainring
3T Arx ii stem 120mm -17*
Barfly faceplate + mount
ENVE SES 40cm aero bars
Berk Dila 140mm UD unpadded
Lizard Skins 1.8mm bar tape
S-Works Rib or ENVE cages or Arundel mandible cages
J&L Ti stem bolts & chainring bolts
Light-Bicycle W56 or ENVE 5.6
Specialized Rapid Air 26mm tires
1190 11-32 cassette maybe 11-30
Need recommendations for bottle cages and have to decide what I want to do for wheels. The enves have an unbeatable warranty and are bling as hell. I would get the light bicycles built with DT 240 hubs and sapim spokes so they weight would be similar.
Any recommendations for stuff to change out?
dudemanppl
by dudemanppl
no -17 stem please
fix shifter angle
you need a new bb
romanmoser
by romanmoser
what are you planning as main use for an allez sprint with a 42 -11 30 or 11 32 ?
The allez sprint is a criterium, race bike ,
quite stiff, but harsh ride for training and hanging around
Hope you won't have issues with misaligned seattube
or ovalized bottom bracket :p
Squashednuts
by Squashednuts
Keep the pedals :lol:
Silver and blue, nice combo
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
by Nefarious86
Roman have you done significant kms on an allez? They're fine for 200km days if you pick the right components, the days of ultra harsh alloy are well behind us.
Sent from my SM-G977B using Tapatalk
Using Tapatalk
CrankAddictsRich
by CrankAddictsRich
icantaffordcycling wrote:
Wed Aug 07, 2019 8:24 am
XX1 11 speed chain
I don't understand this chainring cassette combination? What are you planning to use this bike for? I feel like you're going to be severly undergeared when it comes to flat or rolling conditions.
Nefarious86 wrote:
Thu Aug 08, 2019 11:07 pm
I don't entirely agree with this... The Allez sprint is defintiely better than previous alloy bikes, but it is still a pretty stiff, race bike. You could certainly do 200k's on one, I have, others I know have as well, but I wouldn't say it was the best choice I ever made.
spdntrxi
by spdntrxi
^ kinda agree with Rich.. 42/11 gear... that's like a gravel setup... hell my gravel rig is 40/9
icantaffordcycling
spdntrxi wrote:^ kinda agree with Rich.. 42/11 gear... that's like a gravel setup... hell my gravel rig is 40/9
Junior gearing is the short answer.
Just a little over 100 gear inches but I have friends that have gotten away with 42-11. Way better than 52-14 as there are no lightweight 14-28 cassetes (Ultegra is the only option and heavy). Pit wheels at crits use 11-28 cassetes.
Last edited by icantaffordcycling on Fri Aug 09, 2019 1:53 am, edited 1 time in total.
spdntrxi
by spdntrxi
^ that explains it then...
icantaffordcycling
Didn't get time to weigh each part individually so this is the best I got. Effin customers ImageImage
tonytourist
by tonytourist
CrankAddictsRich wrote:
Fri Aug 09, 2019 12:12 am
When did you get a Sprint? :noidea:
icantaffordcycling
Napkin math puts me at 7.4kg or so. Under 7kg would be nice but highly unlikely. Hopefully not too bad all things considered (alloy frame + discs)
CrankAddictsRich
by CrankAddictsRich
Ahhh.. I got it. That explains it.
tonytourist wrote:
Fri Aug 09, 2019 2:37 am
I don't have a sprint. I have an SWorks DSW Allez, the generation prior to the sprint. My best training buddy is on an Allez Sprint, though, so I'm pretty familiar with both and have ridden both. We've both done 100+ mile training rides on our bikes, so it can be done, but we would both choose our carbon bikes over the Allez frames. My Allez doesn't have the DSW bottom bracket, which is definitely stiffer, but I think the downtube on my bike is thicker and the seat stays are beefier on my frame. The Sprint frame has smaller seat stays that are dropped, which generally aids compliance, but the seat tube and seat post on the Sprint are aero shaped and offer little compliance.
As I said, I don't entirely agree... the Sprint is an awesome bike. The bang for the buck represented by the Allez frames is incredible. I still use mine all the time and really enjoy it, but its defintiely not the same as my Tarmac when it comes to long rides. My teammate has a Sprint and an SWorks Venge. He loves the Sprint, but would definitely choose the Venge for long rides.
