What pressures are you running your 28mm's at?
Shrike
by Shrike
Got some 28mm clinchers on for the first time, but I'm not seeing anything definitive about the pressure to run 'em at.
Usually run 25mm's and kinda able to go by feel now, though 85/80, give or take a bit depending on what I'm doing or how much risk I feel like taking. I usually weigh between 75 to 80kg.
What sort of pressures you guys had success with. I'm hoping for a cushier ride :P
Attermann
by Attermann
I run my 30 mm tubeless at 4 bar front and 4.5 back
Edit: forgot to add that I weigh 88 kg
bm0p700f
by bm0p700f
Pressure depends on the tyres, your weight and what you like. Go and experiment.
spdntrxi
by spdntrxi
60-65psi
Stueys
by Stueys
70f/75r, 78kg on 28 tubeless
hoojammyflip
by hoojammyflip
25mm Vittoria Open clinchers, 23mm rims, 115psi....64kg
If it hurts your butt, you are putting too much weight on your saddle/not pedalling hard enough. My tyres have a minimum written on the side, something like 110psi.
spdntrxi
by spdntrxi
hoojammyflip wrote:
Sun Aug 04, 2019 10:02 pm
you didn't read the title did you ?
by Nefarious86
Specialized Roubaix 25/28 on a 22mm internal rim, 33mm actual width and in the mid 60s for psi at 85kg
Sent from my SM-G977B using Tapatalk
Using Tapatalk
TobinHatesYou
by TobinHatesYou
Nefarious86 wrote:
Mon Aug 05, 2019 12:43 am
Goddamn that sounds plush.
Lugan
by Lugan
I weigh 81-82 kg. I have 28c Schwalbe Pro One on 21.0 mm wide rims, run tubeless. They measure about 30mm wide at 60psi front and 75 rear. I ran them as low as 55 and 70, but they were a bit to squirmy and vague.
by Nefarious86
It's pretty good, the wider C38 rim really helps take the squirm out of them at low psi and if I know I'm going to be pushing the pace I'll add 5/10psi to take the little bit of squirm they develop out of the equation but for going out and grinding through Z2 they're perfect in the 60s range.
In saying that I hit near 75km/h this morning with no issues in the dark down the sweeping descent to the Spit bridge.
Everything from rolling kms to A grade Podiums with a simple 10psi adjustment lol. Keen to try the Corsa Control 2.0 once these finally wear out but I'd say I'll be waiting a while at the rate they seem to be wearing. ImageImage
Using Tapatalk
pdlpsher1
by pdlpsher1
GP5K 28s, 61.2kg, 75 front/80 rear, 17C rims, actual tire width 28mm
rides4beer
by rides4beer
28mm GP5Ks, measure at 30mm on 20c rims, 80psi front, 90psi rear, 84kg rider. Maybe I could go lower, but they're comfortable and I don't want to risk pinch flats, the roads here can be pretty bad.
Alumen
by Alumen
Vittoria Rubino Pro's, 6 bar or 8 PSI, 92kg.
My personal experience is that good cushioning comes from a quality tyre with high TPI, rather then from the tyre pressure itself.
CAAD 13 Disc
CAAD 10 2015 R.I.P.
28, the real 25
sychen
by sychen
Specialized turbo cotton 28mms, 73kgs. Between 60 to 65 psi normally.
