Spongy lever on disc brakes after travelling
PaulH
by PaulH
When I travel abroad I have a spongy brake lever and have to do a mini bleed to get lever feel back . I am sure I’m doing bleed correctly and there is no air left in system. Does the reservoir in the lever have a small amount of air in (to allow for pad wear) do others have this problem after travelling / inverting the bike , if not is there a bleed trick to alleviate this or should I Cable tie the levers down before travelling , many thanks in advance for any advice.
spud
by spud
to me, anytime you invert the bike you invite air bubbles to migrate from the reservoir into the master cyclinder. I always store disc bike level, or by hanging from the front wheel. I once hung a disc bike by the back wheel, and got a bubble in the rear line which required bleeding.
1415chris
by 1415chris
No experience with road hydraulics but I can't imagine they can be different to mtb. In the case I get spongy lever knowing that the system is bled correctly, I pump the levers for a while till I get desire response.
PaulH
by PaulH
So I guess it isn’t possible to get absolutely all the air out of the system
Alexbn921
by Alexbn921
There is a rubber bladder to compensate for fluid expansion and pad wear. A good bleed will get all of the air out of a sealed system. Air does disolve in fluid though and you need to put a vacuum to get this disolved air out. Changes in pressure and temperature can release this air giving you a spungy lever. Also a bad bleed can leave air in the system. Air loves to hide in the nocks and crannies. Degassing is essential for a nice solid lever feel.
Hexsense
by Hexsense
hmm, interesting.
So is there any difference in air dissolvability between fluid used (Mineral oil vs DOT)?
Can we add heat to get rid of air when we bleed the system?
Alexbn921
by Alexbn921
The two fluids are different and have individual properties related to water and gas absorbing.
Big no to heat. You need to pull a vacuum. Use a bleed kit and it's easy to degas.
TheRich
by TheRich
PaulH wrote:
Fri Aug 02, 2019 4:58 pm
Tie down the lever after arriving.
PaulH
by PaulH
Thanks
spdntrxi
by spdntrxi
1415chris wrote:
Fri Aug 02, 2019 5:35 pm
This is what I do and 9/10 times it's all I need.. that 10th time I bleed
TobinHatesYou
by TobinHatesYou
spdntrxi wrote:
Sat Aug 03, 2019 1:20 am
Even then, I just do the mini bleed procedure where I zip tie the lever for a couple hours, come back, use the bleed syringe or cup on the lever size with a small amount of fluid and just flick the lever a few times to shake the bubbles out. With a SRAM system and syringe you can do one better and push/pull on the syringe plunger to further pull the gas bubbles out.
spdntrxi
by spdntrxi
TobinHatesYou wrote:
Sat Aug 03, 2019 3:14 am
yeah sorry.. I dont do a full bleed either.. just get a few bubbles out of the lever with the cup deal and I'm done.. < sub 5min job and it only takes that long because the lever screw gets stripped super easy so I take my time.
