Short reach aero handlebar recommendations
Miles253
by Miles253
Basically, before I buy my new bike, I'm altering the position of my current bike.
The current set up is 120mm stem 85mm reach Syncros all-in-one. So the reach is long and my fit dictates I should bring it back.
Obviously at this point I've not yet tested the fit, so I've already bought a cheap 75mm reach Deda bar, I'm just trying to source a Canyon stem in a 90 and 100 (I have 110) to go on the Ultimate.
So all in I would be looking to save 30-40mm reach to the hoods.
Making a list of bars as I go. The top two are what I'm using now.
Ritchey (rose) 83cm
Synchros (Canyon) 80
Specialized shallow drop - 75mm
Specialized aerofly - 80mm
Zipp SL70 269.99 70mm reach
Pro PLT - £40
Canyon Ergocockpit H31 - 70mm reach
Sent from my EVA-L09 using Tapatalk
Specialized S-Works Venge Disc | 7.8kg
Rose Backroad | 9kg (Deceased R.I.P.)
Canyon Ultimate CF SL | 7.7kg
https://www.findyourroad.co.uk/
Instagram: @miles_bc
Gary71
by Gary71
What about enve ses aero road?
https://www.enve.com/en/products/ses-aero-road-bar-v2/
They are narrower up on the hoods bringing the effective reach closer to you and wider in the shallow drops for leaverage.
I have them on my Cervelo S3 and can highly recommend them.
Miles253
by Miles253
Gary71 wrote:
Sat Aug 03, 2019 10:04 pm
Nice as they are, I fear these are the ones not compatible with the di2 bar end junction box...
Price too...
by Nefarious86
Sent from my SM-G977B using Tapatalk
Using Tapatalk
Sinicity
by Sinicity
Does anyone know if the Zipp SL70 Aero has internal routing?
IvanZg
by IvanZg
Sinicity wrote:Does anyone know if the Zipp SL70 Aero has internal routing?
Yep.
Miles253
by Miles253
Nefarious86 wrote:Image
I stand corrected! Still, £400 for a bar alone is a bit too rich for my blood.
cyclenutnz
by cyclenutnz
https://profile-design.com/collections/ ... /drv-aeroa
3 drop/reach options with a Kamm top section
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
Miles253
by Miles253
cyclenutnz wrote:
Mon Aug 05, 2019 1:16 am
Very clever, great spot thank you.
cyclenutnz
by cyclenutnz
Miles253 wrote:
Mon Aug 05, 2019 6:47 am
Full disclosure - I designed the bar...
PD was going to do one with a sharp tailed airfoil but I killed that ideal in favour of a kamm shape as it's more comfortable and meant that the wing didn't stick out behind the clamp area (because knees against bars are not great).
Catagory6
by Catagory6
3T ergonova
ovalized flats
77mm reach
comfiest bars i've ever had
moonoi
by moonoi
ProN3wbie wrote:
Wed Jul 31, 2019 6:07 am
I currently run Zipp SL70 on two bikes. I love them to the point where I'm not sure I can ride anything else that isn't 70mm reach.
One day I'll get these bars from Chapter 2 for a dream build. https://us.chapter2bikes.com/mana-handlebar.html/
I did exactly that, bit more flexy than the Zipp SL70 Aero, but only noticeable when sprinting out of the saddle, overall I still prefer the mana integrated bar, to the Zipp SL70.
TurboTommy
by TurboTommy
moonoi wrote:
Tue Aug 06, 2019 5:18 am
Don’t want to derail this thread too much but I’m considering the same switch and I’d be grateful for some of your feedback. I’m trying to decide if I want to go intergrated or not...You mind if I ask how much you weigh and how wide your bars are? Also what bike do you have them on and is the bottom of the bars parallel to the floor? They look really nice I think but flexis something that puts me off intergrated bars a little.
moonoi
by moonoi
95Kg and its on a C2 Tere, I went with the 42/110 bars which are 40cm on the top and 42 in the drops. They are parallel to the floor.
Only time I feel any flex is sprinting in the drops, but it really isn't much at all and doesn't affect your feeling of control. In fact if the Zipp SL70 Aero wasn't so solid, I'd probably not have noticed it.
I also have a pro vibe aero on my Colnago Concept, and those are super flexy....but not suitable for this topic since they are quite long reach bars and I wouldn't recommend them anyway.
Sent from my SM-G970F using Tapatalk
TurboTommy
by TurboTommy
moonoi wrote:
Tue Aug 06, 2019 5:32 pm
Thanks that’s very useful. I’m thinking about putting them on a c64 and the headtube angle to your c1 Tere looks very close. Interesting that you have the concept, because I was wondering if I could make it work with the spacers that come with the bars and the propriety headset spacer that comes with the concept.
