Specialized Epic size help
02GF74
by 02GF74
On large 19 in frames, distance from tip of saddle to bars middle is 56 to 59, that is for 26 and 29 frames so it does vary.
tonytourist
by tonytourist
mihalina wrote:
Fri Jul 26, 2019 8:10 pm
Hello guys
first thank you for all your help. Just curious and I hope last question.:) What is your length from end of the saddle to end of the central stem? My is 560mm, just to know for expample what you get on M with this position that you have as it would be something similar for me.
I'll have to measure tomorrow, I missed your post. Also, are you looking at a current Epic, or an older one?
Here is my XC bike from 2016, also a size medium. The new Epic is definitely different from the older model, but since people are posting theirs I figured I would contribute.
mihalina
by mihalina
Thank you. I went to a store and the guy who is doing fitting for specalized put me on large and fit the bike.
I think for me large is better also guy who is doing fitting said same thing. On medium length to end of the stem would be 52 which is too short for me.
tonytourist
by tonytourist
My setup measured from the nose of the saddle diagonally to the center of the handlebar is approximately 57cm, so I'm not sure why you're only getting 52? :noidea:
4536
by 4536
2018 epic medium is 20mm longer reach than 2017, just fyi. 2018 was all new.
mihalina
by mihalina
tonytourist wrote:
Thu Aug 01, 2019 6:49 am
Tonytourist to the end of the stem, not diagonlay.
I also tried M scott spark which was perfect. With 7cm stem it had 55 this length. Tried also canyon lux l and this was also 55.
How you get 57cm i do not know:) but i was not able to get even 53cm
tonytourist
by tonytourist
I meant that if you grab a tape measure and measure from the center of the stem and pull it to the saddle nose in a straight line, my measurement was 57cm. If you don't run a lot of setback and use a short stem I can see where it would be an issue.
mihalina
by mihalina
Hi
No due to my leg proportion i need to have saddle forward to get it fittee right. Due to this i have then issue with length of the bike.
@tonytourist I am also using zero offset setpost. So that I why I have on M quite a big issue with reach.
