New S-Works Turbo Rapid Air tubeless tyre
anykarthik
by anykarthik
26mm tire weight: 260g
28mm tire weight: 314g
Definitely heavier than the Hutchinson 11storms that are coming off the bike for this. The 28mm Hutch was 270g. Didn't really have any serious complaints with the Hutchinsons. So the Spesh Rapidair had better be impressive in grip/feel for me to be happy with the switch.
spartan
by spartan
the weight discrepancy between 26 and 28 is huge. curious how wide the 28mm get mounted on the rim with 21mm internal width.
Current Rides:
2019 S-Works Tarmac SL6 Bora Di2 9150
sychen
by sychen
icantaffordcycling wrote:
Tue Oct 01, 2019 6:28 am
Has anyone figured out what is special about the rapid-air sealant? I am not happy with the regular specialized sealant because of how it dries. Rapid-air sealant looks thicker and smells like it is not ammonia-free, whereas the 2BLISS ready sealant is. They market that with roval rims + rapid-airs + rapid-air sealant you can inflate with a floor pump but I had the same result with orange seal. Not sure what is special about it and couldn't find any information about it.
https://www.velonews.com/2019/10/bikes- ... rse_501198
A new writeup on velonews on the construction and sealant as well.. worth a read.. not sure if its just industry BS.
Ritsuke
by Ritsuke
Anyone know whether they will have a version with tan walls?
Current: 2017 S-Works Tarmac SL5 | SRAM Red Etap | Edco Umbrial 45 - FFWD F6R Ceramic
Projects: 2021 TT Project | Frame Unknown | Shimano Dura-Ace Di2 | Pro Disc - TriSpoke
Retired: 2019 Specialized Allez Sprint Red Hook Crit
icantaffordcycling
by icantaffordcycling
Ritsuke wrote:
Thu Oct 03, 2019 8:50 am
Nothing in the pipeline. Tan walls on tubeless are kind of weird.
sychen
by sychen
Not just weird.. It's not the natural colour.. The pro one with tan walls are artificially coloured vulcanised rubber.
Non TL tan/gumwall tires are naturally that colour.
cpark
by cpark
spartan wrote:
Wed Oct 02, 2019 1:10 am
I just mounted a set of 28mm on the CLX 32 wheels with 20.7mm internal width, and one measures 29.96mm and the other one measures 29.93mm at 80 psi.
One weighs 317 grams, and the other weighs 315 grams vs. the advertised weight of 305 grams.
They did go on pretty easily on the wheels by hands.
I'll check the air pressure in the morning to see how well it retains air.
I'll be riding them with 65 psi on the front and 75 psi on the rear.
cpark
by cpark
cpark wrote:
Mon Oct 07, 2019 1:00 am
Update:
They plummed up to 30.81 and 30.76mm over night. I squuzed the tires, and it felt just as plummy as last night, so I believe the air retention is excellent.
I took the pressure down to 60/70 and took it out for a quick spin, and it felt very comfy.
IceLed
by IceLed
Really helpful, thanks for the update!
S-Works Venge 2019 Battleship
Previous bikes:
Canyon Aeroad CF SLX Disc 2019
Canyon Ultimate CF SL Disc
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
Ritsuke
by Ritsuke
Thu Oct 03, 2019 9:38 am
Anything for the looks. :oops:
Imaking20
by Imaking20
About 120 miles into my use of these 26s and loving the ride. In the ~5 days they've been aired up, they've grown to just a hair under 28mm at 75psi on my CLX 50.
Today I got my first puncture on them. On the one hand, they sealed up almost immediately and I probably wouldn't have even noticed were it not for the fact that I was rolling from a stop and heard a brief hiss. In this regard, I'd say this setup absolutely lives up to the claim/hype.
On the other hand, it's a little unfortunate that between these and the Schwalbe, I've had as many punctures in ~3 months as I had the year prior riding tubulars exclusively.
At least they correct themselves relatively quickly? :)
IceLed
by IceLed
Cool, what sealant are you using?
Sent from my SM-N960F using Tapatalk
Previous bikes:
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
Imaking20
by Imaking20
RapidAir
sychen
by sychen
Just installed a pair of 28s.. On Roval CLX50 disc
Went on easy. Seems to not need any soapy water tricks.
Didn't pop when pumping up (regular track pump).
Holds air pretty well without sealant, Easily got to 90psi.
How much sealant are you guys adding? Recommended 60mls. Only had one bottle so added 30ml each.
Letting it sit overnight at 90psi but already at 31mm.
They are much larger than 28mm turbo cottons..
sychen
by sychen
Did my ride today.. Lumpy 80kms.
One grew to 30.1mm..other 31.1mm.
Faultless.. Just as assured as Turbo Cottons.
Ran them 60/70 front and back.. A bit bouncy at this pressure. Will drop 5 and will be about right.
One visual thing I got used to is the rubber on turbo cottons is the seamless middle as its a rubber strip bonded to the cotton casing .. The Rapidairs join down the middle.
