STR9170 Hydraulic Shifter Poor Spring Return
ymisyd
by ymisyd
Hello,
My RH 9170 shifter has progressively been getting worse when it comes to the spring return. The left shifter "pings" back into the parked position but the RH one is very slow and doesn't have a positive spring return. This is causing the front pads to drag every time I brake. It's now got to the point where I'm manually pushing the shifter back to the parked position every time I brake.
I've cleaned and lubricated the front pistons but no difference.
Any help appreciated.
Vjl
by Vjl
I can almost guarantee it's a lazy piston.
Klaster_1
by Klaster_1
Does it return if you push the pistons in? Did you check the lever tension spring?
TurboKoo
by TurboKoo
I’ve seen few cases where thin film layer of J-KIT has not been “punctured” correctly and that has created restrictions on oil flow. Check that first from the caliber end. If possible cut hose just little and put new insert and olive.
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
ChiZ01
by ChiZ01
I got the same issue with my 8070 lever, without anything connected the lever would fail to reset 20% of the time, feels like something is causing friction to the master cylinder piston, can i put lube into the piston?
ymisyd
by ymisyd
Vjl wrote:I can almost guarantee it's a lazy piston.
Thanks for the tip. Any advice on what to do to resolve this? I'm thinking of disconnecting the hose on Monday and starting with a fresh fill and bleed. This should at least give me an opportunity to make sure the shifter spring is ok.
Any other maintenance tips while I've got it all in bits? It's a self build and all the bits are only about seven months old.
bikeguy0
by bikeguy0
I had same issue and had it warrantied. I rebled, cut hoses and new olives, and reoiled caliper piston seals and nothing worked.
TonyM
by TonyM
ymisyd wrote:Hello,
How old are they?
And how many km/miles with them?
ymisyd
by ymisyd
TonyM wrote:
Sat Jul 13, 2019 3:15 pm
ymisyd wrote:Hello,
How old are they?
Seven months old
2500 miles
ymisyd
by ymisyd
bikeguy0 wrote:
Sat Jul 13, 2019 2:53 pm
Which part was replaced under warranty? Shifter or caliper?
bikeguy0
by bikeguy0
Entire shifter.
joren
by joren
same problem over here .
ymisyd
by ymisyd
So, today I bled the brake. A couple of tiny bubbles but nothing major.
I noticed, after researching, that everybody warns against operating the brake too much without pads in because the pistons will come out of the caliper. However, no matter how many times I pumped the lever, the pistons only ever came out about 3mm - no more.
Does this give any clues to the problem? After bleeding, the brake lever still won't spring back to the parked position. Is the caliper user serviceable? I can't find any documentation.
Thanks.
Broady
by Broady
Shifter warranty. Same thing happened to me, luckily was picked up before installing.
dricked
by dricked
I too have this problem. I thought it was maybe some air trapped in the lever still but I guess not.
