Setback post recommendations
galr1
by galr1
I’m looking for recommendations for a new post to replace an S14 vcls on a canyon ultimate evo. The VCLS is fine but I’m not needing the damping and a bit of weight reduction would be nice.
Need 27.2mm x 330-350mm with 10-15mm setback. Saddle is a berk with 7x9 rails.
75kg rider on good roads and looking for something reliable.
Any recommendations? Thanks!
wheelsONfire
by wheelsONfire
Bike Ahead The seatpost.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
DJT21
by DJT21
Deda Superleggero fits the bill.
tmchen
by tmchen
Deda Superleggero +1
arty118
by arty118
I'm using Ritchey superlogic 1-bolt on my Ultimate CF SLX. Pretty light and comfortable. You will need new clamping parts for 7x9mm rail though
flying
by flying
I have had a few The SB32 from FSA I had broke
& in the end to be honest the China Carbon type is fine
The only drawback is you need a saddle with a cutout as one bolt faces up
There may be a way around that but I use Flite saddles so no prob :wink:
191gr
nickf
by nickf
Darimo set back post is pricy as hell, but it's one of the most aesthetically pleasing to look at. My darimo straight post has been great and I'm around your weight, no issues.
moyboy
by moyboy
+1 for MCFK, but the latest versions don't have setback. The older ones did.
Juanmoretime wrote:
Fri Jul 12, 2019 10:39 am
Pricier but MFCK is plenty light and strong. I spent years on one with zero issues.
galr1
by galr1
Thanks for all the tips.
MCFK seems to suggest the saddle can be set far back even though the post is straight, at least from their description?
Darimo looks a good bit lighter than the others for not much more money, so hopefully I can find a buyer for the canyon post :-)
wheelsONfire
by wheelsONfire
What is great with bike ahead is the anti-slip surface. Forget that this seatpost moves. You can apply less torque and it still is seated.
If you want to make it lighter, you can change the top clamp for "yokes". It's M5 threads.
This saves you 20 grams. I run Ax Lightness yokes on my Bike ahead seatpost.
Finally, yes, it offers more seatback than MCFK.
Bikes:
Ex bike; Vial EVO D
DJT21
by DJT21
nickf wrote:
Fri Jul 12, 2019 1:19 pm
Yeah, the Darimo post looks good.
Another option: WR Compositi WRC seatpost.
cadence90
by cadence90
galr1 wrote:
Thu Jul 11, 2019 11:49 am
WR Compositi RS or WRC in 20mm setback are superb posts.
If you can find a NOS or mint PMP SB14 (14mm setback) that would also be great. (PMP no longer make these posts new, afaik.)
Both of those are very high quality, very durable, and beautiful.
No idea on how the weights compare to a S14 VCLS, but easy enough to figure out.
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
Wookski
by Wookski
DJT21 wrote:
Fri Jul 12, 2019 10:17 pm
My Darimo in UD gloss came in at 80g
The WR WRC was over 130g in gloss 3K but much better quality
galr1
by galr1
Thanks very much, just ordered a WR WRC and pair of their C16 skewers, should be a good saving - bontrager Serrano rl (240g) canyon VCLS (225g) and DT RWS qr skewers (100g) to be changed out.
cadence90
by cadence90
galr1 wrote:
Sat Jul 13, 2019 3:04 pm
Excellent choices. You will like the WR components I'm sure.
