S-Works Tarmac SL6 - Tidying up the front end (One piece bar & stem)
GeeTee
by GeeTee
So despite the release of the new Supersix Evo, Scott Addict and Focus Izalco Max, I'm still leaning towards an S-Works Tarmac SL6 Disc.
The only thing that's putting me off is the fact that unlike the other bikes I'm just mentioned, the SL6 doesn't allow you to hide the cables. It's not enough to put me off, but I'm keen to hear/see what can be done to tidy up the front end.
I'll be running Dura-ace Di2, so thinking of heat shrinking the Di2 cable to the rear disc brake hose (which I think runs into the top tube from memory). However, there may be more that can be done.
Great brains of WW, what say you good fellows?
by Nefarious86
Aerofly bar and heat shrink, size the cables appropriately and they will look neat.
The front was slightly long but I was being lazy and knew my stem length wasn't final with these bars, the rear would actually hug the frame more with about 10mm more length but I wanted it to float off the frame and not rub. Image
Sent from my SM-G977B using Tapatalk
Using Tapatalk
blehargh
by blehargh
GeeTee wrote:
Mon Jul 08, 2019 10:45 pm
Don’t think there is anything else to do beyond starting to drill holes in your frame/fork. :)
Cemicar
by Cemicar
Some brands like FSA or Ritchey are releasing very interesting projects, and they might work with Tarmac...
https://www.visiontechusa.com/ja/node/3277
https://bikerumor.com/2019/04/05/ritche ... resh-more/
And indeed, I've seen several DIY people already had great success in hiding Di2 cables by passing them through the top head bearing (like below), although they had to peel the coating of the cable.
rsantos450
by rsantos450
I also have a SL6 S-works, and i dont like the cokpit, it needs a more aero stem or cleaaner look, don't know what stem to change... ;)
calleking
by calleking
I have a rim braked SL6 and I'm using Aerofly bars, Zipp Sprint SL and heat shrink tubes. Don't think it can get much better without using something like the solution posted above.
2018 S-Works Tarmac SL6 Sagan Superstar DA Di2
2016 Focus Mares CX
2016 Grand Canyon AL 8.0
Retired: 2014 Crux Elite, 2017 Cannondale Slate Ultegra, 2016 Aeroad CF SLX 8.0 DI2
g32ecs
by g32ecs
The solution is to wait for the SL7 as it looks like they "hid" the cables. It should be next year.
The photo below looks like a solution that Cannondale did. If Specialized were to follow Scott they'll develop an integrated bar or a 2 pc solution that still hides everything
rsantos450
by rsantos450
I have a rim brake version, don't need more for what i ride.
rsantos450
by rsantos450
https://www.google.com/url?sa=i&source= ... 0298340657
If the size fit un the headset, is a nice stem...
rlanger
by rlanger
The new Deda Vinci system looks hot and could be just what you need:
http://www.dedaelementi.com/en/vinci/
rlanger
by rlanger
calleking wrote:
Thu Oct 31, 2019 12:17 pm
Did you route the cables yourself through the Aerofly? Have one on order and just curious about what I'm in for. Was it difficult?
Stendhal
by Stendhal
blehargh wrote:
Tue Jul 09, 2019 12:03 am
There is. I own a Tarmac SL-6 and use an integrated bar-stem without this issue. It's because I run SRAM eTap.
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
scale29
by scale29
How's that? Do you not run brakes?
blehargh
by blehargh
rlanger wrote:
Sun Nov 03, 2019 12:59 pm
I didn't think it was too bad - but I am using the park took internal wiring kit with magnets.
Found it easier to route the housing through the shifter hole first and then through the frame.
Also if you're going to do shrink wrap, make sure you think thru the whole process a couple times. For some reason it was mentally challenging for me and I could've messed it up at multiple points
Jimboslice
by Jimboslice
Nefarious86 wrote:
Mon Jul 08, 2019 11:27 pm
What bar ad stem are these? Slick look.
