Budget lightweight seatpost options needed
addictR1
by addictR1
Looking for a new seatpost for an upcoming build that won’t break the bank. Probably 350mm length.
Any suggestions?
Prefer one that doesn’t have too much graphics
LouisN
by LouisN
27.2 mm I guess ?
Setback ?
I've been using those for 4-5 years without any problems, 27.2 mm on our road bikes and 31.6 mm on our CX bikes. They can handle any kind of rails.
Not too heavy IMHO:
https://www.ebay.com/itm/187g-Carbon-Se ... 1438.l2649
Louis :)
addictR1
by addictR1
Sorry should’ve been clear. Need 31.8 and no setback
Squashednuts
by Squashednuts
Hylix on eBay
https://www.ebay.com/itm/Hylix-Carbon-S ... MsiWq8SUww
I’ve got a 27.2mm with setback
Seems good quality and advertised weight
Fuji SL 5.5kg tubs/5.9kg viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
JerryLook
by JerryLook
I’ve been using an Zero setback Elita One seatpost from Aliexpress for about 3k miles.
It’s 31.6x350 and weighs 133g. I’m 85kg and it hasn’t broken yet. Lol.
I got it on sale a few months ago, and it was around 20$. I think they might be 25$ now.
Edit: here is the link
https://m.aliexpress.com/item/329691423 ... 2457591273
2010 Orbea Opal 54cm
5.97kg
alcatraz
by alcatraz
That elita one is the latest generation cheap seapost out of china. It weighs around 130gr.
It goes under many names as well as noname so don't just search for elita one.
It should be available for around 30usd. In china it costs around 23-27usd.
addictR1
by addictR1
alcatraz wrote:
Sun Jul 07, 2019 2:15 am
thanks... i found one on aliexpress... $21. but won't get it till 8/1... :(
dereksmalls
by dereksmalls
I’ve had a couple of Hylix ones off eBay and they’ve been great! Light enough at a good price
alanyu
by alanyu
Hylix + 1
Super light round seatposts and bottle cages made in China are usually reliable.
Orbital
by Orbital
JerryLook wrote:I’ve been using an Zero setback Elita One seatpost from Aliexpress for about 3k miles.
I’m using the 27.2 version. Swapped the alloy yolk for a J&L carbon one to save 8g and gain some surface area for my carbon seat rails and it’s 113g all said and done. Supplier claims hardware is titanium but I might swap to black plated titanium hardware anyhow.
addictR1
by addictR1
Do you have a link for the carbon yolk?
Wonder if it will fit the one I bought from Ali
Orbital
by Orbital
https://www.ebay.com/itm/J-L-Seat-post- ... SwRfxb7t91
I had to modify the seatpost as the cradle radius was tighter than the radius of the yoke. I used a dremmel and a lite file and took my time to match the profile. Was a bit time consuming because I was concerned with making it as even as possible so the saddle would sit level side to side.
addictR1
by addictR1
Thanks!!
tmchen
by tmchen
Wow. I I just fitted mine and so far I’m happy with it too. Mine came in ard 162g tho.
dgasmd
by dgasmd
Just got an AXLightness Europa 27.2 no setback 400 mm and weights in at 135 grm. So long I could cut it by almost 1/3 and still be ok with plenty below. Not the cheapest. Rated at 100 kg rider.
