Lightweight 11sp cassette
addictR1
by addictR1
Held out for as long as I could... found a sweet deal on etap short cage and went for it.
I need a lightweight 11sp chain and cassette... preferably up to 32t. Need at least 30 if possible.
I’ll probably use a wolftooth or buy aftermarket legs so it’ll support 32t.
Thanks
alcatraz
by alcatraz
Sram works very nice with both sram red and duraace cassettes. Possibly even better with duraace. You can try to to score a da9000 28t cassette cheap and later swap the three larger cogs from a da/ultegra 30/32t cassette and mix.
addictR1
by addictR1
alcatraz wrote:Sram works very nice with both sram red and duraace cassettes. Possibly even better with duraace. You can try to to score a da9000 28t cassette cheap and later swap the three larger cogs from a da/ultegra 30/32t cassette and mix.
Wooo.. didn’t know that’s possible
alcatraz
by alcatraz
I was a bit too optimistic.
A shimano duraace 28t cassette has 19-21-23 and 25-28 in two blocks.
On a duraace cassette those cogs are titanium. On ultegra they are steel.
The smaller duraace cogs are steel and should weigh similar to ultegra.
On a da9100 11-30t cassette the big cogs are 19-21-24 and 27-30.
An 11-32t sram red is 195gr but expensive as hell. Duraace 28/30t are 195-205gr
ooo
by ooo
215g ztto 11-32T $63:
viewtopic.php?t=156139
addictR1
by addictR1
ooo wrote:215g ztto 11-32T $63:
Yup I saw that thread as well.. but heard the shift quality isn’t great and noisy?
bm0p700f
by bm0p700f
A miche supertype 11-32t is 195g. Theres 13 and 15T alloy sprockets though which are too small for me in that material. Spinners would not care about that though.
KCookie
by KCookie
Just go with the Sram 11-32, mine weighed 193.9g, all one piece so no damage to the free hub matched with either KMC SL or PYC 1101 chain. Both within a few grams of each other around 218g.
Sent from my SM-G960F using Tapatalk
addictR1
by addictR1
KCookie wrote:Just go with the Sram 11-32, mine weighed 193.9g, all one piece so no damage to the free hub matched with either KMC SL or PYC 1101 chain. Both within a few grams of each other around 218g.
Thanks.. that’s what I’m thinking too... just wallet is hurting so bad already.......
alcatraz
by alcatraz
I'd try the ztto. Looks pretty good with durable steel on the small cogs.
Maybe if you're a heavy low cadence rider stick with sram full steel, if your're a lighter/spinner then ztto should work great.
I like that they have 11sp lightweight options up to 36t. Noone else makes a light 11s 36t cassette.
KCookie
by KCookie
Yeah, fully understand that. Image
Wingnut
by Wingnut
Is there a lightweight steel 11spd Campagnolo compatible cassette that’s actually cheaper than original Campagnolo?
Miche?
"It's not the destination...it's the ride!"
Alexandrumarian
by Alexandrumarian
Miche is heavy, but shifts fine and offeres different tooth counts. If you want light steel, Sram is prob the only option and it is pricey. Some people say it shifts fine, others say it doesn't...
