Tubeless tyre pressure
devonbiker
by devonbiker
Hi, can anyone tell me the optimum tyre pressure for Continental GP5000 Tubeless 25mm on Giant SLR 1 30mm rims.
I am 68kg and bike weighs 7.3kg.
Assuming I’m riding on a dry summer’s day.
Thanks
probertsqbe
by probertsqbe
Your a similar weight to me. I’m not running tubeless but have been experimenting with tyre pressures this year.
I’ve been able to run 70psi at the front and 75psi at the rear when conditions are wet and i need a bit of extra grip without pinch punctures.
In good dry conditions i typically run 80psi and 85psi front and rear.
I’m running Michelin Power Competition 25mm tyres on Aforce rims (19.6mm internal)
Best advice is to try different pressures and settle on range for different conditions based on the type of riding you do. I guess you moved to Tubeless to have the option tom run lower pressures?
mag
by mag
Also similar weights (65 + 7.5 kg) and tyre widths here (26mm measured) and I run about 65-70 PSI front, 75-80 rear.
I usually have a fairly low loss of pressure so I'm able to pump it to the higher ends of the values mentioned and then run with that for 2-3 days until the pressures drop below the lower ends...
RocketRacing
by RocketRacing
71/74. It is all about road conditions however. Smooth is fast.
I use the sram tyreWiz app for my starting points. Seem pretty reasonable.
Also verify that your pump is putting out good numbers... otherwise it is an exercise in futility. I use a silca superpista digital and it is fantastic. I am 20lbs lighter and 70/72psi is advised for me.
Orlok
by Orlok
devonbiker wrote:
Mon Jul 01, 2019 3:47 pm
Thanks
Very simple: 10% off 68kg is 6,8 bar on normal clincher 23 mm tyres, to 25 mm less 0,5 bar and tubeless less 1 bar on general, so the results are 5,3 bar or 80 PSI (rear). :wink:
Once comes a time that you'll have a tailwind :D
Pinarello F10 - Ultegra 6800 - Carbonspeed C38 - Tubeless
alanyu
by alanyu
I'm 55kg, bike with everything 8kg. Also a bag around 8kg when commuting. My front 28C 5000TL starts from 80-85psi, and I'm a lazy man, so pump once a week. Every time I pump again, it remains 65-70psi. The suggestion of 28C 5000TL by conti is 65-94psi.
dim
by dim
70 front, 75 back (thats what I have my conti 5000 TL (25's) on my Trek Emonda (I weigh 72-73Kg)
Trek Emonda SL6
Miyata One Thousand
devonbiker
by devonbiker
I'm using a Bontrager Charge foot pump.
I was running 85 PSI front and rear but it always dropped to 80 PSI almost immediately or after the first ride then after a couple of days it settles at 60 PSI.
I found pumping beyond 80 PSI quite difficult.
So I am going to pump to 80 PSI from now on, which probably mean that I'll be riding on about 75 PSI.
Alexbn921
by Alexbn921
I agree with what the others have said. 70-80 depending on conditions and how light you ride. some guys smash into potholes and need more PSI
