10 speed crank with a 11 speed drive train?
Juanmoretime
Administrator
by Juanmoretime
Yes I did a search but am looking for a quick answer. Have a new 10 speed SRAM Red crank but thinking about an 11 speed etap drive train including 11 speed chain. Can I expect any issues?
RESIDENT GRUMPY OLD MAN.
alcatraz
by alcatraz
Short answer: No
The inside width of the links is the same.
Long answer: The spacing between chainrings could be different. 10s isn't as bad as running a 9s crank. When the spacing between the rings becomes too large there is a chance the narrower 11s chain could get stuck between the rings.
Also it's possible you won't get 100% of the intended front shifting performance with different chainring spacing.
However this is usually not an issue. Generally it works fine.
Marin
by Marin
I'm running 10s and 11s Red cranks, they are identical.
