M4lukz
by M4lukz on Tue Jan 21, 2020 6:31 pm
dannywin42 wrote: ↑Tue Jan 21, 2020 5:47 pm
bespoke wrote:That frame looks immense in the sun !
Even better up close. It won't let me upload a gif I made of the shift
Sent from my SM-G975F using Tapatalk
try Imgur or smth with an external link for the gif?
dannywin42
by dannywin42 on Tue Jan 21, 2020 9:47 pm
bespoke wrote:Lush !
Did you buy a frameset only? or is it a full bike and you swapped out the wheels?
Full bike and swapped wheels. I wanted di2 ideally but be reet, I'd take da mech over anything but da di2
pmprego
by pmprego on Wed Jan 22, 2020 12:01 pm
REDUTOPIA wrote: ↑Wed Jan 22, 2020 10:59 am
okimy wrote: ↑Sat Jan 18, 2020 11:21 am
Tubulars
6.85kg
weighet with:
pedals
bottle cages
two bottles
a standard di2 with powermeter
and even computer mount and garmin edge??
is there to trust ??
Weird, isn't it? Because I don't see anyone else achieving similar weights.
mpower
by mpower on Wed Jan 22, 2020 3:58 pm
Scott Addict RC Pro, size XS 49cm
- Lightweight Meilenstein 24
- Shimano Dura-Ace disc R9120
- Look Keo Blade Carbon Ti Ceramic
- San Marco saddle.
Complete bike build at 6.87kg with pedal.
JMOS
by JMOS on Wed Jan 22, 2020 5:41 pm
pmprego wrote: ↑Wed Jan 22, 2020 12:01 pm
Tubulars
6.85kg
weighet with:
pedals
bottle cages
two bottles
I would assume that the frame used by the Mitchelton Scott team is not the same frame as the pro frame sold to the public. If you compare the ultimate frameset and the pro frameset, the pro is rougly 80 g heavier. I would assume that the frame used by Mitchelton Scott is in fact an ultimate frame in pro disguise. Doesn't explain the measured weight differences entirely though.
g32ecs
M4lukz
by M4lukz on Wed Jan 22, 2020 7:06 pm
JMOS wrote: ↑Wed Jan 22, 2020 5:41 pm
I wouldn't be surprised if the Frame is the HMX-SL or an even "higher grade" carbon frame in disguise, nor if the paint in those bikes is some super high-tech one, like the one Pinarello and Ineos are using, like the F1 Cars... Ultralight paint can help you save some grams here and there. Also, they're running Tubular tires and wheels, which tend to be ever so slightly lighter...
pmprego
by pmprego on Wed Jan 22, 2020 8:08 pm
M4lukz wrote: ↑Wed Jan 22, 2020 7:06 pm
Yep, paint alone is adding some 200 to 300gr
C36
by C36 on Wed Jan 22, 2020 10:55 pm
What are the stiffness numbers? The picture is low res and i font speak german
hum seems Tapatalk reduce the quality of pictures... here an extract of mydatabase.
Neither the last Addict or Izalco are really impressive comparing to quite older frames (Tarmac, SSe2 or Ultimate)
- stiffness table
pmprego
by pmprego on Thu Jan 23, 2020 12:08 am
C36 wrote: ↑Wed Jan 22, 2020 10:55 pm
All of that seems the addict not for 2020.
Source??
