Scott Addict Disc 2020
pmprego
by pmprego
Beancouter wrote:
Sat Dec 21, 2019 5:24 pm
Have set up a separate thread for my strip and rebuild but weights for frame and fork below (excl bearings, clamp; inch hangers and cage bolts).
Didn’t think was to bad against claimed weights (unspecified size and model);
What is the thread with the full build? :)
Beancouter
by Beancouter
Scott Addict RC30 (2020) - Strip & Rebuild
https://r.tapatalk.com/shareLink/topic? ... source=app
FactoryMatt
by FactoryMatt
i wonder what the next foil ends up weighing. cant be much more than 1000
Beancouter
by Beancouter
Straight though seatpost arrived.
156g -4g (the little aluminium bits on the seat clamp). Post is 400mm long, so once trimmed by about 100mm should be about 130g
Macias
by Macias
Just ordered my Addict RC Pro with the Creston SL bar/stem 40cm x 100mm in Canada Scott will receive them late february, early march...
Meanwhile ill try to get every single part required for the build and would like to know your suggested BB ?
Guess ill put my commute bike on the trainer :shock: , zwift time with a baby bench on the back!
Beancouter
by Beancouter
Just found a great article online, with full strip down on an RC30 - in Portuguese but have translated some of below (it’s not perfect!)
Totals
Total Disclosed: 7.95Kg
Total Measured: 7.80Kg
Wheels
Rear wheel with rim tape: 929g
Front wheel with rim tape: 789g
Front Axle: 33g
Rear Axle: 63g
Tires: 284 / 274g
Disk 160: 130g
Camera: 92g
Components
Frame with center: 999g
Handlebar, stem, changers and cables: 1255g
Fork: 382g
Saddle: 245g
Brake Caliper: 156g / 141g
Cashier:
Canote: 139g
Clamp canote 7g
Streaming
Cassette: 291g
Crank: 682g
Rear gear: 180g
Front Transmission: 89g
Chain: 245g
https://www.pedal.com.br/teste-scott-ad ... 14123.html
Macias
by Macias
Just found those 2 amazing builds on youtube!
g32ecs
by g32ecs
Macias wrote:
Sat Dec 28, 2019 6:00 pm
PMd you
Macias
by Macias
g32ecs wrote:
Tue Jan 07, 2020 5:09 pm
PMd you
And since I didnt post enough on the forum yet, I cant reply to you :shock:
I've ordered a 56 with a 40cm x 100mm handlerbar/stem combo :D
g32ecs
by g32ecs
Macias wrote:
Tue Jan 07, 2020 6:53 pm
PMd you
Did you get a deal for your frame and handlebar?
Macias
by Macias
g32ecs wrote:
Tue Jan 07, 2020 7:32 pm
PMd you
Yes, staff deal! Since I work for a Scott Dealer :D
M4lukz
by M4lukz
Macias wrote:
Tue Jan 07, 2020 8:32 pm
PMd you
That does bring some benefits :wink:
Beancouter
by Beancouter
For anyone struggling to see the new Addict IRL, the pic below is the best one I have seen for the ‘red’ ....
I wouldn’t order solely on this photo (!) but think it is understated on the Scott site..
M4lukz
by M4lukz
Just out of curiosity, how's the availability of the scott addict rc where you live? I've ordered a full build on october, and I'm yet to see it on my LBS...
Beancouter
by Beancouter
Patchy - I noted before, if you go to the Damian Harris website it shows you the dates they are due in stock from Scott . A lot of availability in April / May
