Scott Addict Disc 2020
pmprego
by pmprego
NickJHP wrote:
Mon Dec 16, 2019 4:59 am
Nautiboy wrote:Need some help here....
Anyone know whether the Hope RX4 Flatmount calipers (which can be fitted to AXS) can be mounted on the new Addict front fork??
Should be ok, as I have RX4 calipers on my Open UPPER fork, which uses the same method of bolting through the fork leg directly into the caliper.
Sent from my Pixel 4 using Tapatalk
But then will a 160mm work? Aren't you going to need a 180mm?
NickJHP
by NickJHP
pmprego wrote:
Mon Dec 16, 2019 5:29 am
Yes, a 160 should be fine - I'm assuming that Scott have positioned the mounting holes for that size disc. As already mentioned previously in the thread, if you want to use an RX4 caliper with this method of mounting, you need an RX4 rear caliper, because unlike most flat mount calipers, where the front and rear calipers are identical and the front caliper fits to an adapter plate that bolts to the fork, the RX4 front caliper is designed to bolt directly to the standard fork flat mount without using the adapter plate.
pmprego
by pmprego
NickJHP wrote:
Mon Dec 16, 2019 11:02 am
This part is confusing for me. I guess to my lack of knowledge and experience on the subject. But on the topic of disc calippers, I have a postmount caliper from SRAM which ideally I'd use in the rear of my addict. My goal was also to use 140mm rotors. Can this be achieved with some type of postmount to flatmount adapter?
I know shimano sells some adaptors but I really don't know if it will fit the frame (the rear triangle). Does anyone know?
TobinHatesYou
by TobinHatesYou
pmprego wrote:
Mon Dec 16, 2019 11:26 am
It's confusing me too. The Addict fork utilizes normal flat-mount calipers in a 140mm rear configuration (without adapter plate) except the bolt bores are lined up to accept 160mm rotors. The rear RX4 has the adapter plate's dimensions built-in. It wouldn't work.
This is a different scenario than the Campy H11 situation where the front caliper is 160mm only with no provisions for the bolt-through method so you have to use the rear 140mm caliper.
FactoryMatt
by FactoryMatt
tinfoil hat.....there's a conspiracy to force 160 front rotors on World Tour bikes to force commonality. therefore alot of brands eschew the shimano-engineered flexibility of the reversible bracket in favor of a fixed 160mm front rotor.
IOW they're trying to force consensus that 160 front is the ONLY way to go. if you don't need the heat capacity, i.e. don't do sustained descending, 160s are way overkill.
Beancouter
by Beancouter
Anyone have any thoughts on an alternative integrated bar? I am assuming not but worth a ask...
FactoryMatt
by FactoryMatt
Beancouter wrote:
Mon Dec 16, 2019 8:59 pm
i hate where they put the stupid report button on this forum....
it's a 1.25 steerer so options are limited. maybe canyon? maybe giant? deda has a two piece setup.
smz5969
by smz5969
Anyone has an image of how the L size will look like on the Ultimate or Pro? I am pretty skeptical about it being too big on the front end considering the integrated handlebar looks hideous.
pmprego
by pmprego
smz5969 wrote:
Thu Dec 19, 2019 8:59 am
I do like the integrated handlebar. But I ordered one so i'm probably not the best person to evaluate. As for the size, I guess it will be proportional to the rider. You don't put Yates on an L or Froome on a XS.
C36
by C36
Beancouter wrote:Anyone have any thoughts on an alternative integrated bar? I am assuming not but worth a ask...
Farsports f1 is an option. They are making custom spacers. Not sure if the Scott is yet ready.
Discussed here
viewtopic.php?t=159692
smz5969
by smz5969
Thanks for the tip!
pmprego wrote:
Thu Dec 19, 2019 10:48 am
Beancouter
by Beancouter
I contacted far sports a few days ago about the F1 handlebar and they confirmed that the custom parts for the 2020 addict were in their plans for next year - no indication of when though.
REDUTOPIA
by REDUTOPIA
It is a fantastic paint job:
FactoryMatt
by FactoryMatt
that's some really nice Vaporware! :)
Beancouter
by Beancouter
Have set up a separate thread for my strip and rebuild but weights for frame and fork below (excl bearings, clamp; inch hangers and cage bolts).
Didn’t think was to bad against claimed weights (unspecified size and model);
