FSA Afterburner 30/42 mtb crankset with campy 10-speed ?
Catagory6
by Catagory6
would this crankset be compatible?
campy 10-speed FD/RD
KMC 11-speed chain
currently campy 11-speed crankset 34/50
and works flawlessly
alcatraz
by alcatraz
Mtb has a different chainline and wider q-factor. You'd probably be better off using an adventure crank if you need easier gearing. Fsa has them in 46/30.
If you had to pick an mtb crank it's probably better to go triple. Putting a larger chainring in the middle and removing the outer would be closer to road chainline.
alcatraz
by alcatraz
White induetries sell road cranks in any size. You can get a 44/28 if you want. :)
Catagory6
by Catagory6
alcatraz wrote:
Mon Jun 10, 2019 11:15 pm
ahhh, now i see mtb standard is 73, vs 68 for road
is that something that can be compensated with shims?
alcatraz
by alcatraz
The spindle is of a fixed length. In the old days you could put a "road" square taper bottom bracket and use an mtb crank on.
You could still today but it's not very modern.
The spindle is only a little bit longer. The rest of the q-difference is in the arching of the crankarms.
The q-factor could be even desireable if you are very tall and prefer a wider stance.
alcatraz
by alcatraz
In any case. Either use an older road triple crank, or look at fsa cranks. They have small bcd road cranks.
That way you won't run into fit issues later.
