Disk wheel recommendation needed
Noctiluxx
by Noctiluxx
I have a friend who's looking to lighten his Cannondale Caad 10 disk with some lighter wheels. His current wheels are some low end Fulcrums that weight close to 2000 grams. He's about 180-lbs and has a budget uo to $1000.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
Multebear
by Multebear
Just pick something from Farsports or Light-Bicycle and he's good to go.
bm0p700f
by bm0p700f
Or ask a wheel builder.
For 1000 usd I would get the carbon ti centrelock hubs in 24h drilling and kinlin xr31rts rims. Weight 1530g with cx tays. No doubt some would say the hed Belgium+ rins which are lighter but I prefer the deeper more aero rim.
Bigger Gear
by Bigger Gear
bm0p700f wrote:
Tue Jun 11, 2019 7:50 am
Yeah I'm that guy who would say get the HED Belgium Plus. I have 2 centerlock wheelsets built with them, one with King R45 and the other with DT240S, both 28/28 and Sapim CX-Ray spokes. They've both been bomber for me, and the King set has seen a fair bit of gravel and rough riding on my gravel bike. The rear rim even has a little dent from an errant rock, I'd hate to gouge up a carbon rim doing that type of riding.
Between disc and rim bikes I've got 5 wheelsets with HED Belgium/Belgium Plus and they are on my bikes for 90% of the riding. My Enve wheels don't see much action.
Multebear
by Multebear
Just out of curiosity, why are you recommending aluminum rims for a disc brake setup?
Bondurant
by Bondurant
Presumably because of the budget.
dim
by dim
Bigger Gear wrote:
Wed Jun 12, 2019 3:28 am
I am also a happy owner of HED Belgium Plus rims with Chris King R45 Hubs (ceramic bearing upgrade) with Sapim Cx Ray spokes (20/24).... amazing wheels and mine have thousands of miles on some crappy roads and have never had to be retrued from day 1 .... mine are rim brakes though.....
Downside to the Chris King Hubs is that you have to get them serviced from time to time and you need to find an LBS who is skilled at this
If I were to get disc brake rims, I'd probably look at something in carbon though with a decent spoke count if I were to also do a bit of 'off road'
Trek Emonda SL6
Miyata One Thousand
TonyM
by TonyM
dim wrote:
Sat Jun 15, 2019 6:59 pm
All hubs have to be serviced from time to time......Sorry for that I could not resist.....LOL...
And you are right with Chris King, they should be serviced by an authorized CK dealership.
I personally love the DT Swiss hubs (espceially the ratchet system) and they are so easy to service yourself!
dim
by dim
TonyM wrote:
Sat Jun 15, 2019 7:06 pm
my Chris King hubs get serviced twice a year (I do high mileage) .... £65 per service (for front and rear) .... i.e. £130 per year
Trek Emonda SL6
Miyata One Thousand
TonyM
by TonyM
How many km is recommended between 2 services for the CK hubs?
bm0p700f
by bm0p700f
Over here the heds are so expensive that you would blow the budget with hed rims are light hubs like the carbon ti so for the budget and the weight target my original suggestion is still good. Kinlin for me and I have built with hundreds and they never crack. They are nice and round, flat and so good i struggle to actually find a practical way the hed rims are superior. Now the kinlins are coming in Matt finish even the aesthetic advantage has shrunk.
kafreeman
by kafreeman
bm0p700f wrote:Over here the heds are so expensive that you would blow the budget with hed rims are light hubs like the carbon ti so for the budget and the weight target my original suggestion is still good. Kinlin for me and I have built with hundreds and they never crack. They are nice and round, flat and so good i struggle to actually find a practical way the hed rims are superior. Now the kinlins are coming in Matt finish even the aesthetic advantage has shrunk.
I'm with you... xr31t is hard to beat. Both sets I've built were flat, round and built up easily.
Sent from my SM-G965U using Tapatalk
dim
by dim
TonyM wrote:
Sat Jun 15, 2019 8:55 pm
from the Chris King manual:
http://www.starbike.com/manuals/r45-r45 ... -21-16.pdf
Rear Hub Maintenance schedule
Chris King R45 and R45 Disc Hubs are designed to provide long life and high performance.
Beyond an occasional adjustment, the only maintenance necessary is cleaning and lubricating
the RingDrive (see “The RingDrive”, pg. 8), and re-lubricating the bearings (see “Service of the
bearings”, pg. 10). Riding conditions will determine how often to service your hubs. As a beginning guideline, your hubs should be serviced every 6-12 months in normal and dry conditions
and every 3 months in wet or muddy conditions.
The Chris King bearings in your new hub are of the highest quality. However angular contact
bearings will settle and eventually wear in with use. Since looseness or “play” in the bearing
assembly can develop as a result of wear, Chris King hubs have been designed with an adjustable bearing preload mechanism and any normal play can be eliminated (see the appropriate
“Adjustment” section, pgs. 3, 5, 6 and 9).
Trek Emonda SL6
Miyata One Thousand
Squashednuts
by Squashednuts
Noctiluxx wrote:
Mon Jun 10, 2019 3:09 am
Caden wheels
https://carbonbikewheels.com.au/en/prod ... r-wheelset
1160g for tubular 50mm
1430g for clincher 50mm
About $1800 Aus$ About $1250US$
Great guy to deal with, shipping included in the price
I had a pair of the tubulars, great wheels
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
