Cat piss cycling shoes
tarmackev
by tarmackev
Is there a cure? After wet weather riding and drying my shoes have the dreaded cat piss smell.
Like a creaky BB it sometimes disappears but give it a little wet weather and boom “Cat Piss Shoes” are back.
Any suggestions that doesn’t involve burning them?
Many thanks.
Powerful Pete
Location: Lima, Peru and the Washington DC area - it's complicated.
by Powerful Pete
Hello there - I have no advice to give but I am sitting in an airport lounge and you made me burst out laughing. Now some people are staring and giving me nasty looks.
Here’s to hoping others can help...
Supercommuter: Jamis Renegade...
Oldie but goodie: De Rosa Professional Slx, Campagnolo C-Record...
Ride4Life
by Ride4Life
Did a cat piss on your shoes or just smell like that because they got wet/mildew smell?
Dan Gerous
by Dan Gerous
Happened to me too years ago, then girlfriend's cat pissed in my mountain bike shoes, she offered to buy me a new pair... until she saw the price of the shoes so we gave it a go at trying washing them, I don't remember what we used, I think we tried clothing wash liquid, dishwashing liquid but after a couple of washes (long soak, working the soap in with stiff brush, rinse, dry, repeat), the smell eventually left for good. That was almost 10 years ago, I still have the shoes and they still smell fine, they outlasted the cat! :mrgreen: It might depend of the shoe material too, mine were made mostly of mesh, plastic-like material and padding inside.
mikemelbrooks
by mikemelbrooks
You can keep your shoes in a plastic bag, but really it depends on what is causing the smell, with some running shoes its the glue that holds them together. If it is the bacteria from your feet there are various odor sprays and powders. I think probably alternate shoes and actually put the shoes in a freezer overnight to kill the bacteria (inside a plastic bag). Do your feet smell?
mag
by mag
Piss on them yourself. Mark them as yours...
Dan Gerous
by Dan Gerous
mag wrote:
Fri May 31, 2019 4:09 pm
:mrgreen:
spdntrxi
by spdntrxi
they sale that liquid for rugs and such at pet stores... buy a bottle and soak
mag
by mag
Simple things such as vinegar, baking soda and perhaps citric acid should work too. Though if that smell comes from the glue I'm afraid they won't help much.
wheelbuilder
by wheelbuilder
What you really need to do is go to the nearest zoo and get some tiger piss. Put some on the exterior of your car and drive around your neighborhood. Then put a very small amount around the area where you keep your shoes. This will ensure that every living animal in the area will know there is a true Apex Predator around and they will all fall into line.
spdntrxi
by spdntrxi
wheelbuilder wrote:
Fri May 31, 2019 5:40 pm
just watch out for euro blondes and 8 irons
FIJIGabe
by FIJIGabe
Back to the original topic, I had a similar problem with my CX shoes (I wouldn't term them "cat piss" but seriously "funky"), and would suggest the following:
1. Remove the insoles and just wash those in your washing machine.
2. Spray the inside of the shoes, liberally, with some white vinegar. You're really just trying to kill as much of the bacteria as you can, which is what is causing the smell. Let the vinegar sit for a bit, then put the shoes under a strong fan to dry them. Repeat this at least twice (more, if necessary).
3. If you've done this and the smell remains, try diluting some detergent in water and spraying that into the shoes, letting them sit for a bit, then thoroughly washing it off with warm water, to get the soap out.
4. Once all of this is done, put the shoes to dry (under the fan, again), then use some OdorEaters and liberally coat the inside of the shoes. You can also use baking powder, as I've done in the past.
tabl10s
by tabl10s
Have five, but one likes to piss on clothes. A different one F'd up my $275 leather Orthotics. Sprayed and washed three times and jacked up another pair when I washed them together.
Finally smell free.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
1415chris
by 1415chris
Boot bannana, nice scent, absorbs moisture, neutralises and prevents an odour. However didn't try with cat piss...
Orbital
by Orbital
I had a cat that decided to use my hockey bag as a litter box. Figured it out while sitting on the bench between shifts. I ditched the gear and replaced it. Kind of related to the OP issue, to get the funk out of my hockey gear I soak it in regular laundry soap and rinse
Quite gross but this is after one season playing for 2 teams.
