Training With Zero Metrics
scapie
by scapie
AeroObsessive wrote:
Tue Jul 09, 2019 3:29 am
scapie wrote:
Tue Jul 09, 2019 2:29 am
i started a thread specifically about training with zero metrics and you two both can't help yourselves can you? You just have to start dribbling on and on and on about exactly what this thread is not about.
why not go start your own?
someone called me out about not contributing so thats what i did. you want me to call you both out? it would be extremely easy.
Welcome to the internet. Are you new here?
lol. you get a pass but only because you're an OG here.
AeroObsessive
by AeroObsessive
^ and I do apologize for the derailment of topic.
The concept of NO metric is really hard to comprehend for a data junkie such as myself.
However the endeavour of training with nothing would be a very interesting one, if only from the pure psychology of it. I was a guinea pig for a TT study once, 40km TT with NOTHING. No time, pace, power, anything. It was an... Interesting experience.
scapie
by scapie
Tue Jul 09, 2019 3:49 am
Not even the internal temperature probe? They probably could have accomodated if you had have asked nicely ha ha!
AeroObsessive
by AeroObsessive
^ oh, they had that *well* in. I should clarify - the boffins were recording everything, I just wasn't privy to any of it while doing the TT.
iheartbianchi
by iheartbianchi
Tue Jul 09, 2019 3:28 am
1) you point of FTP being "off". In what context, and how was it tested?
2) wattage IS the one output that is the most important. Everything else we measure (HR, gas exchange, lactate) is *usually* as a result of that work being done. HR is an outlier as it can fluctuate regardless of work being/not being done. Power, and power alone (over time), can be used to develop very accurate, and effective training. The extra data sets help confirm. Information either confirms or informs, and in this vein more is better.
3) RPE and power - personally, I find these highly informative. Especially when there's a clear disconnect.
Thought experiment: if you had only one source of data, HR, power, speed, lactate, gas, whatever -combined with time, which would yield the most certain information of the work being done and hence the adaptations likely to take place?
I posted links to I think 3 studies testing the linkage of FTP to lactate threshold, which all came to the same conclusion - it was nowhere close. Power alone cannot be useful - you need some other variable. What you are implying (power alone), would only be useful if you had a very accurate sense of RPE.
If I had to choose only one source of data, I would go with HR. If I had to choose two, I would go with HR and lactate threshold.
Bianchi Oltre XR4
Celeste Matte
Campy SR 11spd mechanical
Bora Ultra 50 tubs
Viseon 5D / stock bits and parts
Bianchi Specialissima Pantani Edition
Campy SR / Chorus 11spd mechanical
Fulcrum Racing Speed 35 tubs
FSA / Deda bits and parts
iheartbianchi
by iheartbianchi
TheRich wrote:
Tue Jul 09, 2019 1:55 am
This is a strawman holding a red herring.
If you're not going to respond to what I wrote, don't respond at all.
Show us on the doll where the FTP test touched you.
You keep saying power is more accurate than HR. I am responding that this is exactly the problem. Power measures only power. HR measures only HR. Both are useless unless linked to something that is happening in your body.
Bianchi Oltre XR4
Celeste Matte
Bora Ultra 50 tubs
TheRich
by TheRich
iheartbianchi wrote:
Tue Jul 09, 2019 6:29 am
If I find a power output that I am happy with as far as RPE and HR goes, it is easier to maintain that power when using a power meter. That has nothing to do with FTP or anything else, I'm just talking about looking at the display. It is more accurate than HR because it says what you're doing right now, whle HR will lead you to hunt for the right exertion level as it lags up and down.
...and quit making it an either/or proposition because nobody has suggested that, because it's silly.
iheartbianchi
by iheartbianchi
TheRich wrote:
Tue Jul 09, 2019 6:43 am
The statement you wrote was "power is more accurate than HR for measuring effort." This is not even accurate and the premise itself is flawed. Power doesn't measure effort. It measures work. You are equating work with effort, which implies you are doing some kind of weird calculation in your brain to connect power values to physiological effort (probably FTP).
Bianchi Oltre XR4
Celeste Matte
Bora Ultra 50 tubs
AeroObsessive
by AeroObsessive
Tue Jul 09, 2019 6:27 am
And there are studies that shows that in trained persons it matches pretty with MLSS reason well... depending on the protocol and various methodology used.
https://www.ncbi.nlm.nih.gov/m/pubmed/29745765/
https://www.ncbi.nlm.nih.gov/m/pubmed/3 ... 65/related
Oh looky, I can use Google too 🙄
For those who like a bit of reading and some good reading to the pros and cons of FTP, read this:-
http://marktallonphd.com/the-myth-of-fu ... power-ftp/
Should people use FTP in my opinion? It depends.
iheartbianchi
by iheartbianchi
Tue Jul 09, 2019 10:16 am
You can google, but can you actually understand the study?
The first one uses Bland Altman analysis and produced a result of 95% LoA of 1.4 ± 9.2% in its group of trained/well-trained cyclists. That means in 95% of the results they were within 9.2% of their MLSS (in the trained group, it was 11.8% difference). The second study shows very similar results. Mind you, the FTP test was conducted in labs in highly controlled settings with technicians standing by - if we are dealing with 12% deviations for these trained cyclists in a lab, I don't even want to imagine how far off a recreational athlete doing a test outdoors will be.
And I don't like to "play games" with statistics, but based on the study you cited, you're looking at a theoretical range of 18.4%, or 23.6% in the trained cyclist group! Think about what that means. It's actually comical how inaccurate FTP is, and yet people want to sell you training programs and coaching based on FTP, when you can just get your lactate tested for not much money at all, and avoid all of this guesswork (I reiterate that I think power meters and lactate testing is overkill for amateurs, but if you are going to use a power meter as some kind of measurement of work and by correlation, effort, then at least take your training seriously enough that you're not guessing how hard you are working).
But I digress. If you are happy with 12% deviations from your MLSS, more power to you. But you may as well be using the 220-age formula to calculate heart rate zones if you insist on wildly guessing. And at least be honest and up-front that well, if you use a power meter and FTP zones, you could be very far off your lactate threshold. There is no such disclosure or disclaimer anywhere (partly because people decided to revise the definition of FTP so it now has nothing to do with lactate levels, how convenient!). But you get a lot of people saying how accurate power meters are. Yes, it is largely accurate in measuring your power output, and yes it can be an effective pacing tool / measurement of effort if you tie your power values to anything but FTP.
Bianchi Oltre XR4
Celeste Matte
Bora Ultra 50 tubs
AeroObsessive
by AeroObsessive
Tue Jul 09, 2019 3:45 pm
Now we are getting somewhere. Except you don't need to tie it anything more than time, if you have enough collated power data (20-30 sessions inc some racing).
Believe it or not, close enough really is good enough for effective training.
TheRich
by TheRich
You're making a semantics argument
Tue Jul 09, 2019 6:50 am
Which was what I was saying.
MattMay
by MattMay
Wish there was a thread about training without metrics. Oh wait....
cdorcy
by cdorcy
scapie wrote:
Thu May 30, 2019 8:44 am
I don’t train every week all year but when I do I will do 2 sessions per week and 1 harder ride on the weekend. After a few weeks when my fitness has started to come up I will ad in a tempo session mid week. For the rest of the time I just ride easy.
I have a power meter on my bike but I only use it for pacing when I want to test my legs. I never use heartrate. I’m not at all interested in FTP. All of the interval training I do is no longer than 5 minutes.
Could you comment on what kind of interval sets you find most effective for your hard sessions? Sounds like some tabata style sessions...any other go to sessions? Thanks.
scapie
by scapie
cdorcy wrote:
Fri Aug 16, 2019 1:31 pm
Sure, I’ll post a it a bit briefly and if you’re interested just ask and I can add.
I have a tacx trainer and I preprogram the workouts in their cloud app then load up the sessions when I need them.
Here are 3 workouts;
2 sets of 10x 20sec on 20sec off @3% slope
1 set 10x 30sec on 30sec off @ 2.2% slope
1 set 10x 1min on 1min off @ 2% slope
20, 30 and 60 second would be my bread and butter interval sessions on the trainer. I always start with shorter intervals first and then work towards longer duration. I do this because I feel that to raise your power across different durations you must first raise your top end ceiling, or vo2 I guess you could say.
The efforts are real simple stuff. What is difficult is 1. adjusting the load volume correctly for you level of fitness and overall condition and 2. Going hard enough. So for example when I start out I don’t think I would be fit enough to hit 20 reps of 20sec efforts. Well, I could do them but I couldn’t do them hard enough to be worthwhile. Therefore I would adjust to 2 sets of 6 or 8 and also adjust the rest between sets to 10 or 12 mins. Because that session is very intense but ultimately low overall volume I would add in the tempo session on Wednesday so that way when I start the Thursday session my legs are already overloaded a little. Once I get fitter I just lower the tempo and boost the intensity volume.
There is endless variations of these efforts you can do. Its not so much the duration of the effort you can play with, but the duration of the recovery. I think a 1:1 ratio is good for stuff under 1 min but you can play with how long you rest between sets. The less rest you have the harder its going to be. It’s a bit of a fine line though.
