Using Specialized Venge Front End on Madone SLR
cajer
by cajer
So the Madone SLR Rim in it's smallest config still has too much reach for me. This is due to it's long reach bars (93mm) and a shortest stem length of 90mm. I don't want to go with a non-integrated front end as that defeats half the point of the bike. However the specialized Venge (non-VIAS) front end still allows for cable routing through the stem and looks like it may work with the Madone cable routing without using the stem adapter.
Does anyone have any thoughts/opinions?
TobinHatesYou
by TobinHatesYou
The Madone uses specific integrated stem specific headset cover that interlocks with the stem or spacers, so I'm not seeing how you could cleanly integrate the Venge cockpit without using the adapter headset cover for normal stems.
cajer
by cajer
I was thinking of grinding off the interlocking portion of the top spacer, and then using the venge fairing to cover everything. I understand that the Venge fairing won't be a perfect fit, but it should still be cleaner than user the adapter headset
Noctiluxx
by Noctiluxx
The Madone is already complicated enough (pain in the ass) with the OEM cockpit. I can't even imagine a mechanic who would like to tackle that job.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
cajer
by cajer
It would be me doing this haha. However after giving it some more though. If it was even slightly not clean, it would drive me crazy. So I am going to wait and see what Felt comes out with this year. If it's not good, I'll go with the new Cervelo S5 disc. Though I hate disc...
Slack
by Slack
I’m using a venge stem on a system six because I really dislike the knot bar and stem, mainly the Garmin mount poking up in the air like an afterthought. It looks good and you can just sand/file the spacers so they integrate as you’d like.
alcatraz
by alcatraz
Swap to smaller frame size.
Stretch before riding. Inflexible riders don't mate well with aero equipment.
cajer
by cajer
Already on the shortest size. I'm just going with a specialized venge stem and a normal aero drop bar
alcatraz
by alcatraz
Does the madone have womens sizes?
TobinHatesYou
by TobinHatesYou
alcatraz wrote:
Sun May 26, 2019 1:23 am
They have women’s trims with different saddles and stem/bar lengths, but the frames aren’t any different. Trek only offers the Madone down to 50cm in part due to how small the main triangle is with the those massive tubes.
