Colnago C-60 and Stages powermeter
dgasmd
by dgasmd
Just wondering if there is anyone here that is using Stages Powermeter on the non-drive side and having no clearance issues. I don’t thing there would be any, but wanted to have an idea before I send cranks in for permanent changes!
LeMomo
by LeMomo
Which chain set are you wanting to run? Crank arm shape makes more of a difference.
Assuming that you already have the frame/crank and are just wanting to add a left only unit, you can check for sufficient clearance using a 10mm hex key to check the gao between chainstay and standard crank arm. I’m fairly sure that there is a guide to this in the stages website.
ipenguinking
by ipenguinking
I have Shimano power meter (DA arm) on my C60 and there is plenty of clearance. I don’t think Stage’s ‘box’ is bigger.
dgasmd
by dgasmd
LeMomo wrote:
Sat May 18, 2019 5:49 am
Will go to their site and see if I find the info. Thanks.
This would be for a C-60 in size 48S running Campagnolo SR 11 sp with 170 crank arm length.
Mockenrue
by Mockenrue
Yes, I have a 172.5mm Stages Campag arm and used it on my C60 no problem. Frame was a 52s.
dgasmd
by dgasmd
Mockenrue wrote:Yes, I have a 172.5mm Stages Campag arm and used it on my C60 no problem. Frame was a 52s.
Thanks
Was it a gen 2 or 3?? How did you like it? Any problems?
Mockenrue
by Mockenrue
Gen 3; had it since September and used it all through the (shitty UK) winter while my SRM was waiting on new batteries. So far so good - reliable and consistent. I had a Gen 2 in 2017 and it was OK for a while but started to under read and eat batteries so I got rid.
mattcooke
Resident Pro
by mattcooke
I am running a stages with a C60 and have zero problems. Go for it.
