Opinions needed... Best BB30 to shimano BB/adapter
tom007
by tom007
I have a 2019 Specialized Allez sprint disc and am thinking of upgrading to ultegra di2. What is everyone's opinion on BB30 to Shimano bottom bracket adapters/full bottom brackets and the best ones available?
Thanks!
blehargh
by blehargh
Hambini?
You can look at praxis works or i guess ceramic speed.
Hexsense
by Hexsense
I have exactly that, Allez Sprint Disc with Di2.
I prefer Wheels MFG threaded together bb.
It is not the lightest but i like that it is easy to remove and re-install, just in case i need to access di2 cables in the bottom bracket area.
pocari123
by pocari123
Anything threaded. Second the Praxisworks and Wheels mfg as mentioned above.
Have a praxisworks bb30-gxp on my Allez right now and fingers crossed no creaks yet.
SilentDrone
by SilentDrone
I’ve used these from Wheels Mfg and they worked flawlessly:
BB/PF30 Universal Adapter for 24mm Spindle Cranks (Shimano, FSA, etc.)
https://wheelsmfg.com/products/bb-crank ... a-etc.html
alcatraz
by alcatraz
Best in what regard? For install and forget use threaded.
For lightweight I'm sure if properly installed using the right primers and compounds you can get it silent with a simple pressfit cup system.
If you run into alignment issues you can go threaded later.
If your bb shell is already properly aligned there is little to gain with a threaded bb.
BigCol
by BigCol
I' ve been really impressed with my token ninja so far....
https://www.tokenproducts.com/bottom-br ... inja/ninja
* Widely spaced bearings so good support / stiffness
* Uses composite spacers between alloy BB housing and frame - no creaking and less chance of damaging the frame
* Threaded together - keeps alignment and allows very easy installation and removal (no press, just conventional BB tool)
* bearings can be replaced and housing reused :)
* Additional seals seem quite effective, bearings lasting well!
Col.
jlok
by jlok
+1 on Wheels Manufacturing ThreadTogether BB for reliability.
tom007
by tom007
Cheers for the replies, thinking of going for the wheels mfg threaded option. Not too bothered with the added weight, more concerned with reliability. :D
Nejmann
by Nejmann
I’m on bb30a to shimano from c-bear. Works really well.
