Lightest 27.5 XC Full Suspension Frame?
andreszucs
by andreszucs
Just making sure I'm not missing anything.
As far as I know, the latest Scott Spark RC 900 is currently the lightest accessible frame to consumers out there, is there a 27.5 version of the Spark with same or less weight available? maybe a women's version? I can't find a clear answer to that.
I'm just getting ready to replace my beloved 2011 Spark 26" frame in case it gives out on me....running 27.5 wheel with it.
krzysiekmz
by krzysiekmz
Orbea Oiz comes as 27.5 in size small.
1600g without shock but that's claimed weight.
Chris.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
TheRich
by TheRich
You're not doing yourself any favors by going to 27.5 unless you're not tall enough to fit on a 29er.
andreszucs
by andreszucs
TheRich wrote:You're not doing yourself any favors by going to 27.5 unless you're not tall enough to fit on a 29er.
I’m 5’10, but I’m ok on 27.5. I also like all the components on the bike, specially the wheels so the plan would be to do a straight frame swap if I need eventually.
andreszucs
by andreszucs
krzysiekmz wrote:Orbea Oiz comes as 27.5 in size small.
Chris.
That’s nice thank!
TonyM
by TonyM
andreszucs wrote:Just making sure I'm not missing anything.
I have a 2012 Scott Spark 26” and happy to know that it works with 27.5”!
You kept the stock fork etc... or did you change it?
Which wheels do you have ?
Which tires can you use with the 27.5” wheels? 2.1, 2.25?
andreszucs
by andreszucs
Everything stock is gone from the bike. Everything is also maxed out with this 26” frame on size Large. Tires are Maxxis Ikon 27.5x2.2 front and back, the back tire ‘kiss’ the seat tube at full stroke but is not bad enough to worry about. Fork is a DT Swiss EXC 150, that’s right...150mm...amazing fork and I wouldn’t change for anything else, even if I end up changing the frame I would use an adapter from 1 1/8 to taper so I can keep using this fork (1580g). Wheels (1274.6g/set) are kappius rims laced on extralite hubs front and back, cassette is a e-thirteen 9-46, wish is 511% range (More than XX1). Frame weight is currently 1387.6g + 155.5g(DT Swiss XR shock). To adjust the geometry change since the bike gets taller because of the bigger wheel, I made a bushing with 3mm offset in the shock eyelet, so the bike is virtualy the same height as before with a 26" wheel.
Complete bike is 20lbs without water bottles. Its versatile, capable, light and reliable.
That’s why my question if I can find an updated 27.5 frame with thru axle with equivalent weight. It would be a bummer to see the bike gaining weight 8 years later.
TonyM
by TonyM
Looks good!
That makes me thinking about trying some 27.5” wheels on my 2012 Spark and 2012 Scale (both all stock).
andreszucs
by andreszucs
TonyM wrote:
Sat May 04, 2019 5:53 am
Looks good! Image
I'm just not sure if would work on a frame size Small or Medium.
TonyM
by TonyM
andreszucs wrote:
Looks good! Image
Oh I forgot that. Yes my frames are S indeed.
