Pinarello Dogma F8 inGamba born 6.34kg / 13.9lbs
Moderators: MrCurrieinahurry, Moderator Team
KarlC
by KarlC
Not to sure how this one is going to work out but, I thought this was a cool F8 with a bit of a unique upbringing as it started life as an inGamba bike.
InGamba puts on bike tours, their web site says .....
Ever wondered what your perfect day on the bike would look like? We did too.
InGamba was born from a desire to combine the world's best cycling with the most delicious local food and wine. We've made that dream a reality – and now we want to share it with you.
https://ingamba.pro/
They sell packages where you can fly to a destination and pick up your new bike to ride there, then bring it home after your trip. I'm guessing that's how this F8 made its way into the USA.
I got just the frame set and will build it up, some mock up photos.......
KarlC
by KarlC
KarlC
by KarlC
More info added, but this build will go on the slower side.
I need see what stem and bars I want for the best look and to dial in the fit.
Also it will be my 1st time on Campy EPS and I'd like to find a way to hide the interface.
Calnago
In Memoriam
by Calnago
I think your best option is to just use some Gorilla double sided tape and mount the interface under the stem. You want to be able to be able to see the lights when you're setting things up and zeroing things in, and to see what the charge level is like, etc. Easy access will be appreciated down the road, not to mention easy access to the charge port. Since this picture was taken a K-Edge computer mount was added using the two mounting screws under the stem, and the control unit was moved a bit further out, between the two mounting bolts under the computer mount bracket.
Nejmann
by Nejmann
Seriously they make the best colorways at ingamba. Loved them all since 65.1 and now to F12.
I think you should go with the most talon handlebar, in Real life it’s dead sexy.
What wheels is going on this beauty?
Mr.Gib
by Mr.Gib
At one of our hotels in the Dolomites, the inGamba group was also present. Yes the best hotels and the best food and wine. Nice bikes too - it was neat to see so many indentical Pinas lined up in the garage. Professional mechanics taking care of everything. What was most interesting was how few of the riders were well suited to the bikes. Quite a few flipped stems and chubby guys coming back from short rides looking destroyed.
KarlC
by KarlC
Calnago wrote:
Fri May 03, 2019 6:50 pm
Thx for the input Cal you are always on point.
I am thinking of doing somthing more custom to hide the interface and still having ez access, if I have the time and can make it work.
Leviathan
by Leviathan
Mr.Gib wrote:
Fri May 03, 2019 7:51 pm
Welcome to the wonderful world of high end group cycling. The only time I every got really terrified on a bike was when the Trek Tours group was descending the other way, and Waffas not much better.
dgasmd
by dgasmd
KarlC wrote: I got just the frame set and will build it up, some mock up photos.......
Seems like most manufacturers need to talk to these guys to get some lessons in good paint jobs and tasteful color combos!!
nismosr
by nismosr
KarlC wrote:
Fri May 03, 2019 6:36 pm
Karlc no of hiding the interface since the charging port is there too, Cal's picture is how I mount my V3 and V2 interface.
Colnago C64 Mapei - Campagnolo SR11 EPS - Campagnolo Bora WTO 60 - P2Max
3T Strada Due - Sram Force AXS Etap
Basso Diamante - Campagnolo SR11 EPS - Lightweight Meilenstein - P2Max
KarlC
by KarlC
nismosr wrote:
Mon May 06, 2019 8:38 pm
Im hoping I can hide it with some small custom work to the V3 interface and the part I mount it to, we will see.
KarlC
by KarlC
Nejmann wrote:
Fri May 03, 2019 6:58 pm
Wheels for now will be my Easton Aero 55 tubulars that are 28mm wide with 27mm tubulars as this is on only aero set of wheels I have right now.
Seedster
by Seedster
I mount mine under the stem as most do. That said, if you have find an ambitious mechanic with electronics skills and a 3D printer, I am sure they can whip you a bar end junction solution or swap to a mini usb interface. I was considering doing the same. Would be interested in seing your solution.
KarlC
by KarlC
Id love to do one of these trips, but for me it will just be the San Diego coast, without the flipped stems and chubby guy.
Not yet anyway.
rexyi1990
by rexyi1990
Great pictures~!
