Pinarello announcement may 1
moyboy
by moyboy
Saw this..... f12 ? Has the #dogma hashtag.....
https://www.instagram.com/pinarello_off ... n7kkjr2sy5
spdntrxi
by spdntrxi
will it be disc+full aero?
Karvalo
by Karvalo
There was a photo posted in the UCI thread about a month ago.
adilosnave
by adilosnave
Sure isn't anything graceful about that. All those swoops and nothing cohesive so I guess it matches up well with the rest of their product line.
Doesn't matter. All the dentists will be happy.
corky
by corky
Is this a post crash testing example?
C36
by C36
spdntrxi wrote:
Sun Apr 28, 2019 9:01 pm
Both braking systems should be offered, from my friends at Pinarello "to satisfy those looking for performance or something easier".
I find bizarre they went for the kinked top tube after it took way-too-long for Look to realize people couldn't stand it... Now if it is more aero than the F10 that was measured at 213W which is at the level of a Madone (and versus 203W for the current absolute fastest bike - SystemSix) that would be an extremely interesting offer from a performance point of view. Hope they stiffen the frame that was quite flexier than the previous generation (75-85N/deg for the HT when the references are in the 100-110 range) and made the frame les "snappier" at the moment to accelerate.
sethjs
by sethjs
FWIW - the bike in the video is rim brake. Top tube doesn't look quite like the pic posted above. Downtube says Dogma.
ichobi
by ichobi
I did a frame by frame check and it looks like a rim brake model in that video. In fact it looks just like the current f10. Probably just Ineos color?
spdntrxi
by spdntrxi
oh yeah... forgot about that pic.. I pass.
C36
by C36
sethjs wrote:
Sun Apr 28, 2019 10:07 pm
On the pic posted it says also Dogma next to the HT.
MyM3Coupe
by MyM3Coupe
Let me guess . . Another molded in Taiwan, heavy, ugly, overpriced bike with a short warranty?
Karvalo
by Karvalo
I did a frame by frame check and it looks like a rim brake model in that video. In fact it looks just like the current F10. Probably just Ineos color?
Don't think so. Do another frame by frame - you can clearly see the kinked seatstays of the disc F12 pictured, and you can also clearly see the sharp edged triangular fill in of the inside of the TT/ST junction, where the current F10 has a flowing semi-circular fill in, the bottle cage cutout is much deeper than the F10, just like the F12 picture...
It's definitely the rim brake variant of the bike pictured here.
ichobi
by ichobi
If that were true then it's too bad. I cant think of any more uglier than that f12 bike. You can't even imagine one if you try.
icantaffordcycling
by icantaffordcycling
ichobi wrote:
Sun Apr 28, 2019 11:14 pm
I added the specialized fuelcell/water tank and "dogma" in dentist font.
https://imgur.com/dnvCrxs
Bigger Gear
by Bigger Gear
Unless they announce an English or T47 BB then it's just another piece of under-engineered garbage :shock:
