Anyone put a Cervelo S5D on the scale yet?
Cheers!
by Cheers!
Curious to know if anyone has put a cervelo s5D frame on the scale yet. Let’s see some pics and what was the config and size.
Belshazzar
by Belshazzar
Have a S5 Disc in the shop, 56cm with Ultegra Di2 8070, completely stock. Weight came in at 7.8kg.
timmerrr
by timmerrr
My DA Di2 bike with pedals, power meter, cages, computer and mount is 7.7kg
tetedecourse
by tetedecourse
I'm having S5 Disc in the shop, 58 cm with Ultegra Di2 8070, completely stock. Weight came in at 8 kg.
Cheers!
by Cheers!
Anyone brave enough to break down the entire bike and weigh each component?
Frame
Proprietary handlebar
Proprietary stem
Proprietary seatpost
mrlobber
by mrlobber
Frame (bare, 54cm, olive green) 1090g. Need to add hanger, seatstay protector, BB cable guides, seatpost clamp, headset bearings and preload hardware on top of that.
Fork: 394g
Seatpost: 220g, mainly from the clamping hardware, which is super heavy
Handlebar 42cm 272g
Stem 130mm 131g (nice)
Stem 100mm 128g (wtf)
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
Cheers!
by Cheers!
Disappointing...
Cervelo on their Facebook post said a 2019 s5D is lighter than a 2008 SLC-SL.
Which I found amusing. Considering a fully built up 2019 S5D was 1kg over 6.8kg. But I had no data to back up each component.
Mike2580
by Mike2580
Mine in size 58 is 7445gms, with the heavy thru axles, and 26mm turbo cottons and DA cassette
