Build thread Trek Madone SLR Disc and Campa SR mechanic
Calnago
In Memoriam
by Calnago
Yeah, I have the Hozan version. The key to these things is that they butt up against the stop that your working with, in this case it would the edge of the front derailleur arm, allowing you to control the tension smoothly then clamp it down. I’ve actually glued a little piece of Lizard Skin’s “carbon leather” to the edge of the tool that butts up against the component stop so as not to damage the finish of the component.
dgasmd
by dgasmd
Calnago wrote:It’s just a tool that allows you to grab a cable, and tension it against its stop relatively easily and precisely, then keep it there while you tighten the bolt down with a wrench in your other hand. Most bicycle tool manufacturers make some variation of it.
That’s what I thought you were referring to. I have one, the Pedro’s version. Just never heard anyone call it that, so just curious.
Calnago
In Memoriam
by Calnago
Comes from the expression “Shit!...insert a plethora of other obscenities here... I wish I had four hands to do this.” I suppose sometimes three would suffice, but generally it’s for situations when two is just not enough.
ghisallo2003
by ghisallo2003
I genuinely (and not an innuendo-filled joke) have trained my wife to be my front mech third hand tool. I get the tension just right by hand, and then she leans across and tightens the bolt. It has taken 25 years of training and she does the perfect job.
All my friends (at least those whose bikes I look after) benefit.
SchallUndRauch
by SchallUndRauch
So, the Madone SLR Disc frameset is up for sale: https://www.ebay.de/itm/NEW-TREK-MADONE ... 3151273822
Alexbn921
by Alexbn921
That is the frame and size I was looking for last month. Ended up with another frame or I would be buying that one. The red with giant white logo is hideous though.
SchallUndRauch
by SchallUndRauch
Thank you for your valuable esthetic assessment. It's Viper Red, the regular Trek Segafredo colour.
SchallUndRauch
by SchallUndRauch
I looked at the frame, and noticed this in the bb cutout:
A bit disappointing at this price point.
SchallUndRauch
by SchallUndRauch
...but after sending it in, Trek says it's just cosmetic, so here we go!
Immediately, I ran into a host of problems, from banal to profound:
1. My cycling stand's clamp was too wide to grab the seatpost, so I had to modify it.
2. I thought I had a 10mm tool for the Ultra Torque crank, but I don't, so have to order it first. I tightened the Hirth screw as far as I could, but not to 42-60Nm.
3. There are still open questions regarding fit and therefore stem length, so no assembly of the front end.
4. The Trek-Campa-BB-Set went in easily on the drive side and with tough love on the non-drive side. Now the crank spins with different friction in different positions... I presume, just as in Calnago's case, that the cut-out was not perfectly round. Or will it suddenly rotate freely once the crank is correctly tightened? :noidea:
Stitchking
by Stitchking
As you look to be going ahead with this build, can I ask if you have solved your inline barrel adjuster problem? My solution would be to sneak it just inside the base of the stem which would allow you to adjust tension by unbolting the front brake caliper and sliding the stem up off the steerer.
Hard to tell in the photo but I have just replaced the little steerer stop chip and i can confirm it would be accessable and you would still be able to shift in the stand..
Good luck with the build, looks like it will be an amazing bike.Image
Sent from my SM-G935F using Tapatalk
SchallUndRauch
by SchallUndRauch
Stitchking, that is certainly the best idea so far... I will give it a try, but not sure it will work because space inside the spacers is so restricted.
Stitchking
by Stitchking
SchallUndRauch wrote:Stitchking, that is certainly the best idea so far... I will give it a try, but not sure it will work because space inside the spacers is so restricted.
How many spacers are you running? If you have a few as long as you get a slim enough barell should be easier. I run no spacers and I reckon I'd be able to get away with it tucking into bottom of stem
SchallUndRauch
by SchallUndRauch
All of them, for now.
I decided not to put an adjuster into the spacers or the stem, since its use would be quite restricted and it would be another point where two parts of housing could detach.
Speaking of which, the Campa Ultimate Smoothness (?) housing is simply too short for this frame. Two pieces would have to be joined in the stem area. Plus, the smootheness of the cable appears to depend on a layer of permanent lubricant. So I went with Jagwire instead.
Having said that - it is not going well. I had a frustrating day putting the stiff housings into the frame, arranging them around the benda and trying to make shifting work.
If one absolutely needs tweezers and could actually really use an endoscope to set up his bike - go and do something else.
I put Jagwire liner from the "Mechanical Control Centre" (aka Hell come real) to the respective exits, with the funnel end of the liner in the Control Centre. I made metal washers to shorten the distance from the caps that go into the Centre to the liner, and to prevent them from slipping out.
The fruit of my labors: Front derailleur works, but needs herculean force to shift. Definitely not the way it's supposed to be.
SchallUndRauch
by SchallUndRauch
Ok, ok, it has been a while. But here I am again. Still intending to bash Campa on the Madone. But maybe rather EPS.
Having read what @Calnago wrote about potential difficulties putting the battery into the frame, I made this approximation. It has the diameter and length of the original:
So clearly, the fixing point is at an extreme of the battery instead of the middle part. Is that a problem?
SchallUndRauch
by SchallUndRauch
To make sure the battery can be fixed in this position, I made this carbon cradle to be strapped to the Trek Control Center:
And then I understood that the whole IsoSpeed seatpost can be lifted from the frame, allowing easy access to the inside of the seat tube...! So it should be feasible to just use the battery holder that attaches to bottle bosses, but internally.
