RyanH
- Moderator
by RyanH on Sat Apr 27, 2019 10:58 pm
The reason I sold my Cervelo R5ca was due to the THM fork. Super flexy which felt awful when sprinting at high speeds. Not the same fork but my experience with the CT fork matches the reviewers.
elfuinha
by elfuinha on Sun Apr 28, 2019 7:53 am
Hello
I've both fork and my weight is 90kg.
You can check my bikes they are here in the forum somewhere...
Thm CT fork plenty stiff and great Fork.
Thm Scapula F, also a great fork... It is plenty of stiff... The problem will be rim size with the integrated brake...
Só you are limited to some wheels.
Also the setup of the brake it's not easy.
Since I ride Lightweight in that bike it's not a problem.
Maximum rim 22mm, wider rims the brake will not work.
Any other questions fell free.
Regards
PrinceEdward
by PrinceEdward on Sun Apr 28, 2019 11:59 am
elfuinha wrote:Hello
Regards
Just checked out your profile and viewed your awesome moots build. Since I only experienced thm forks with expanded steerer, IMO that the old thm steerer may look more natural on bike with traditional head tube and the tuning and maintenance seems to be grumbled...need mild attitude.
我從使用 Tapatalk 的 Pixel 發送
