Hunt wheels? Quality?
TonyM
by TonyM
I am looking for some wheels for my gravel bike (to build) and I see that many are using Hunt wheels.
https://www.huntbikewheels.cc/collections/gravel-wheels
What do you think about these wheels in terms of quality?
(I am using Campy and DT Swiss wheels for my road bikes)
bm0p700f
by bm0p700f
It's the hubs I am unsure about. Some of them are novatec and they have something non novatec but not bitex. The novatec hubs they use can be fine but bearing life can be variable.
A customer dropped in with one of there hookless gravel rims and wanted the porous schwalbe pro one replaced. I had to pull the tyre of the bead lock with mole grips. There is secure and thee is hunt secure. You won't burp them though on the plus side.
Calnago
by Calnago
bm0p700f wrote: A customer dropped in with one of there hookless gravel rims and wanted the porous schwalbe pro one replaced. I had to pull the tyre of the bead lock with mole grips. There is secure and thee is hunt secure. You won't burp them though on the plus side.
So how would that have played out if that tire needed removal on the road?
spdntrxi
by spdntrxi
you are calling uber / lyft
Marin
by Marin
Hunt quality seems to be decent but they are consistently 100 - 150g heavier than advertised. I even asked and they told me "they're all like this".
Get someone who knows what he's doing to build you a set instead - doesn't even have to cost more.
alcatraz
by alcatraz
Agreed, there is a balance between tight fit and too tight. Tubeless tires do sooner or later puncture.
What isn't a tight fit at all are Schwalbe pro ones on shimano c40 disc brake rims. I can get the bead off the rim with one hand. Yes, that combo doesn't seal very well.
happyon2wheels
by happyon2wheels
I had Hunt wheels on my radar due to good press (albeit mostly UK domestic reviews). Then I read the carbon wheel review in the German magasine Tour (April 2019) where the Hunt wheels were tested along with 10-12 other wheels in the price range of 1000-1500 Euro.
One can argue against the testing method, but most wheels came our unaffected by the brake test others with some damage to the rim. The Hunt wheels exploded!
I have nothing against Hunt, but that test made me change my mind, which is obviously a purely subjective call.
TonyM
by TonyM
Thanks for all the feedbacks!
That helped! Thanks!
AJS914
by AJS914
The Hunt 50s look very similar to the Farsports I just bought. I assume the rims are oem'd from China as I don't see anything that says otherwise on their web site. Basalt brake tracks on the rim brake model which is what most chinese rims advertise. So, for twice as much money you get a 60 day return priviledge and a better warranty. Maybe you get a more careful build?
I'm not quite convinced that wheels like this are worth twice as much as direct from China (Farsports, Light Bicycle).
TonyM
by TonyM
Yes, I am currently looking at these for my gravekl bike to build, together with some 38C tires:
https://www.wheelsfar.com/gravel-carbon ... t-dsl.html
bm0p700f
by bm0p700f
Calnago wrote: ↑
Thu Apr 25, 2019 12:06 am
Impossible to remove at the side of the road. Your could ride then flat though. The fit is not too tight it's the bead lock bump, it's very pronounced. I tried pushing of with my handsm me and customer did and between us we failed.
