Garmin Edge 530/830 Discussion
northshore
by northshore
It isn't nearly as responsive as a smartphone. I get a lot of missed taps with my 830.
TobinHatesYou
by TobinHatesYou
The 830 touchscreen is less sensitive than the 1030’s according to my dry-ass fingers. I almost always have to lick my glove or fingertip in order to successfully swipe between data screens. Drag-scrolling is very unreliable and I just use the up/down arrows at the bottom of the screen.
I do like the features of the 830, but it has minor issues like this. Also the start/stop button got mushy within days of owning it. I’m just glad it’s not a 530 because then mushy buttons would be a huge annoyance. Also occasionally my 830 will seem catatonic with the screen dark, but apparently it’s actually on/running. Holding the power-button for 15s doesn’t seem to reliably powercycle it out of this state, but it eventually rights itself.
It’s still vastly superior to Wahoo’s lineup in both hardware spec and featureset.
kytyree
by kytyree
DC Rainmaker seemed to really like the value of the 530 compared to the 830 but then there was nothing on these problems.
Makes it hard for me to want to switch from the 520+, though I know people have had similar problems with it, mine has been trouble free.
jlok
by jlok
Get the 1030 now if you found a sweet deal. The software is stable enough after maybe 2 years of update.
TobinHatesYou
by TobinHatesYou
1030s have dimmer screens and worse battery life. They also still develop that blue halo after riding in humidity. Every computer has little issues. I would choose the 830 over the 1030 for just about all my riding...while the display is smaller, it is much more readable in all light conditions.
jlok
by jlok
Yea every computer has issues and how you value them is personal. I'd take stable software and big screen as top priority. 1030 battery is enough for a day of navigation so that's good (again, for me).
Regarding the 1030 halo, I got mine warranty replaced and never happen again. I do like the 530 and 830 battery life and brighter screen tho, but unstable software makes it kind of "unusable" to me. It happened on 1030 earlier firmware as well until maybe v7. I wish Garmin would put the experience of 530/830 into good use on 1030 successor.
AJS914
by AJS914
kytyree wrote:
Fri Jan 10, 2020 12:20 am
Reading the comment's on DC Rainmaker's site can be helpful. People there were all over the 530 button problem when it first came out.
I wouldn't upgrade though from a 520+ unless a 530/830 has some killer feature you want. The 520+ seems fairly modern. I'm considering one of those if I come across a blowout price.
pdlpsher1
by pdlpsher1
I have the 830 and generally happy with it. I do have issues with it however thus far I've been able to resolve my issues with some trial-and-error self fixes (i.e. removing and reconnecting sensor as an example). As for the screen redability/contrast, I have experienced washed out screen under certain lighting conditions. I also have a Garmin Edge 130 and I feel that screen has much better redability than the 830. But the 130 is not a touch screen and I believe non-touch screens can be made with better contrast at a cheaper cost. In conclusion I like the 830 but I did experience some annoying moments until I found a fix to my issues.
TobinHatesYou
by TobinHatesYou
It's not the touchscreen aspect, but the fact that the 130 has a monochrome display. With a conventional color LCD each pixel requires 3 emitters for red-blue-green. This reduces brightness/contrast and can result in aliasing issues.
northshore
by northshore
There are some great features on the 830 no doubt, and I can't find a comparable unit feature-wise. Climb pro and navigation are great when they work.
But there are so many little usability annoyances, that I wonder if any of their developers have actually ever tried riding with it!
- frequent missed touchscreen taps
- occasionally doesn't connect to phone
- occasionally doesn't upload finished ride
- froze after routing to destination on the fly
- climb pro at times doesn't register an obvious climb
- data field spontaneously changes to something else
- crash alert triggered when braking quickly
- when off-course, insists on u-turns rather than rerouting.
- battery sometimes drains to empty after a full charge and turning off
- starts recording another ride when I'm at home waiting for the file to upload. Can't use the screen during this, as it constantly auto starts and stops.
- I want beeps for navigation, but not even little darn thing! Beep, phone connected! Beep, sensor detected!
But when it works, it's great...
IrrelevantD
by IrrelevantD
Thanks everyone for the replies and suggestions, found some of them very helpful.
pdlpsher1 wrote:
Fri Jan 10, 2020 6:10 am
Queston for you on this one. I found someone selling a 130 for $100 and jumped on it to run as a backup. I've seen people complain about the 530/830 buttons being "squishy". How are the buttons on the 130 vs. the 830? Would it give me a pretty good idea of what the 530/830 buttons will be like?
My current plan is to keep the 1000 and run the 130 as a secondary/backup using it for the location tracking until the 1000 dies completley. Then I have to make the hard decision.
pdlpsher1
by pdlpsher1
I have no button issues on the 130. I also have a 520 as well and not issues with the 520. I think the 530 uses a different button mechanism but I have no experiences with a 530.
The 130 is a great computer but obvisouly due to the small size the battery life is limited. It may not last if you ride 200mi. or longer on a single ride although I have never tested it on a double century. Screen readability is much better than that of the 520 and 830.
Campervan
by Campervan
I've recently gone from a 520+ to the 830 (I gave the 520+ to the GF), and I find it really good. I opted for the touch screen as I use the top buttons on the di2 to rotate the screen and start/stop. I also use the alarm function as well at cafe's (as well as a lock).
BMC Granfondo 02 105
Scott Scale 940
Boardman CXR 9.4 cxr CX/gravel mongrel
Btwin 540
Specialized Venge Pro Disc
northshore
by northshore
Leave Garmin on bike as anti-theft alarm.
Garmin gets stolen.
You've done it again Garmin!
dim
by dim
people are complaining about touch screen .... LOL Garmin has the remote button gadget/ Edge® Remote Control .... I've been using it for years with my 1000 .... in rain or dry... no need to try and swipe the screen when you are riding at 20 mph
https://buy.garmin.com/en-GB/GB/p/146078#overview
Trek Emonda SL6
Miyata One Thousand
