Advice on Building a 29er HT Weightweenie newbie
ultyguy
by ultyguy
Hi weenies,
Ok I’ve been making do with a run of the mill 29er HT from Canyon for a while, time to upgrade.
I’ve found an Epic s-works frame for a good deal so going to work around that.
Fork- I want a suspension one (100mm) but 500-700 Eur budget? Seems to be some out there on good deals these days.
Groupset- I’m open to suggestions of things that balance weight/price. I want mechanical.
Brakes- don’t want to skimp here, 180/160 I’m thinking.
Wheels- I’ve got some Crossmax SLR 100/142 thru axle that I bought for the canyon but with boost I guess these go the way of the dodo bird. 500-700 Eur hoping around 1500-1600g? I’m 75kg so not mega light.
Handlebar- Carbon option that’s reliable and light?
Other boys I can source from existing stock. I’m aiming for 9-10kg is that reasonable? Size M
boots2000
by boots2000
Since I have that exact frame/bike I will repley (mine is also a medium).
I have mine down to 8.2 kg
Frame S-Works Epic hardtail medium 29er
Fork- Fox SC32 100mm 110mm spacing
Headset- FSA? Came with bike
Wheels Roval Constrol SL 110 front/148 rear (12mm)
Thru axles- Came with frame but look exactly like Ti-Carbon. Front Kabaxle came with fork
Tires Schwable Racing Ray front 2.25/Racign Ralph rear 2.1 both are snakeskin
Stem S Works 100mm
Bars Darimo carbon 680mm
Grips ESI Chunky
Seatpost Darimo Carbon 380mm 27.2
Saddle Sepcialized S Works Power Arc 143mm
BB- SRAM BB30 pressin
Cranks SRM Origin with poweremter with Wolftooth 32 tooth narrow wide ring
Pedals Crank Bros Eggbeater 11
Shifter SRAM Grip Shift Eagle
Rear Derailleur SRAM Eagle XX1
Chain SRAM Eagle XX1
Cassette E13 9-46
Brakes XTR 9000 race
Rotors Shimano XT 6 bolt (wheels were 6 bolt and Shimano doens't make XTR 6 bolt)
Bottle Cages King Ti (2 cages)
Bar Fly computer mount
One Up pump bracket
ultyguy
by ultyguy
Ooo that sounds like a pretty tasty build! Got some pics? I prob would go without the Srm, what pieces do you think were worth the extra money?
boots2000
by boots2000
Yeah- SRM is not needed unless you want to have power- Also, a standard crank will be even lighter.
XTR brakes are eseential.
For me, all of these parts except the drivetrain were worth it.
I am going to try either XTR 9100 or Eagle AXS- I think Eagle XX1 does not shift great. (Shifters, derailleur, cassette, chain)
ultyguy
by ultyguy
Excellent, thx. Yeah I’ve been impressed with the reliability of even lower level Shimano shifting. Was thinking XT single ring set up and saving money for nice wheels.
ultyguy
by ultyguy
Would this fork work or do I need the 44 offset?
https://www.alltricks.com/F-11918-fourc ... 2019_black
boots2000
by boots2000
51 rake is fine- But get the factory if you can swing it. Your picture is the "Performance" model.
boots2000
by boots2000
Here are some pics of my Epic HT-
ultyguy
by ultyguy
Nice ride! I've found an Expert model on discount so I think I'll just go with that to be lazy and avoid the faff in the end...
tonytourist
by tonytourist
ultyguy wrote:
Sun Apr 28, 2019 7:33 am
I thought the Epic HT used a 51mm offset, with the FS using the 42 (RS) or 44 for Fox.
SpeedyChix
by SpeedyChix
Sweet bike and build. What's the widest tire that will fit the rear?
boots2000 wrote:
Tue Apr 30, 2019 5:23 pm
adrenaline junkie
boots2000
by boots2000
I have had 2.3 Specialized Fastrack- But it is not what I would call a "big tire" bike.
The Fox fork will run out of room before the rear end does.
SpeedyChix wrote:
Thu May 09, 2019 11:33 pm
SpeedyChix
by SpeedyChix
boots2000 wrote:
Sun May 12, 2019 4:28 pm
Thanks.
adrenaline junkie
boots2000
by boots2000
I rode the pictured S-works hardtail at a 100 mile gravel race in the Sierras yesterday.
Pretty rutted and rocky in spots- And lots of standing water and mud.
It performed perfectly and was not slower than gravel bikes, and more secure on descents.
Only thing I would do different would be to run a larger front chainring.
